Took some pics of the process -- thanks to Brandon for helping me get it done in a timely fashion.
* Basic shell complete. We are using mostly cabinet grade Oak plywood (3/4") with some 7/8" ply as well (bottom panel and one layer of top baffle).
* I like to use lots of screws... 2" long models.
* Temporary guide setup to build the port straight
* Outline walls of the port... ready for flexible ply.
* Flexible ply installed to make the flare.
* Coming together !
* Filling in across the flare with strips of wood.
* Wood filler in the gaps.
* Fiberglass cloth and resin applied.
* Top baffles going on.
* Hole cut with counter-sink
* In the Jeep !
I installed the only 18" I had laying around in there and it is a hair behind the old Magic Box per watt so far... but this 18" had an extra hard suspension which is terrible in a box this small.
So... based on results so far I expect this box to pull ahead of the old Magic Box once the correct spider configuration is used. It seems to be functionally nearly identically just with more cone and port area (and a bit more volume).
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Results so far with Z v.2 18" D2 with 3 Spiders (too stiff for this box):
420 watts = 144.6
520 watts = 145.5
660 watts = 146.4
830 watts = 147.2
1040 watts = 148.0
1310 watts = 149.0
1620 watts = 149.8
1790 watts = 150.1
1960 watts = 150.4
2340 watts = 151.1
* Let Sub Cool for about 15 minutes *
2530 watts = 151.6
3110 watts = 152.4
3390 watts = 152.7
3530 watts = 152.9
3860 watts = 153.1
4160 watts = 153.4
All results @ 53 Hz / dB Drag on the dash sealed mic position on the TL.
- Jacob Fuller
DAMN SON canz your bulidz me a magic box too??
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
What size did you use Jacob? i guess around 4 c/f after displacement? great scores!!
So if you replaced it with a sub without such a stiff spider, would it perform better on the mic when you test it?
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
  • Who's Online   0 Members, 0 Anonymous, 1546 Guests (See full list)
