POssible yes but will it mess up my amp/speakers?
Your speakers will get uneven power from speaker to speaker. Though Im not sure if it would make a difference for like a dual 4 ohm wired to 1ohm and a dual.5 ohm(if they make those) wired to 1ohm, though subs like that most likely will be very different to begin with.
¿ǝɯɐƃ ǝɥʇ
Depends. I've seen setups with an 8 ohm woofer and 4 ohm woofer. Although they were in seperate chambers and seperate channels on the amplifier. I wouldn't recommend running different ohm loads though. Would be a weird load on amp and subs would behave differently
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Well, I have single 8 ohm 6" speakers and am having a hard time finding a cheap set of 8 ohm 4" speakers so basically I was planning on mixing a single 8 & a single 4 ohm on a channel. If that made sense. :noob:
Depends where you're putting them and what they're being used for.
Midrange drivers: probably fine.
Subwoofers: not a good idea generally.
Hammerdown... 1%
DONT DO IT! It will cause damage trust me. I believe that was why my pyramid crystal got hot. I had one 8 ohm and one 4 ohm 12. Since you are using them for midbass I am not so sure. But I believe no matter midbass or bass you still shouldnt throw off an ohm load. It will still be connected to a channel with a certain ohm load.
it wont cause any damage. Not sure what happened with your amp, maybe it's because it was a pyramid lol.
It's no different than hooking any other speakers up with the same impedance. my subs are .2 ohms different for example.
But yes depending on the impedance your subs will see different power for each given load.
oh yea everything should be in a separate chamber just to clear things up.
Eclipse cd7000
  • Who's Online   0 Members, 0 Anonymous, 1865 Guests (See full list)
