Hdc3-18 Box design help
i want to be able to have my box fit behind my 3rd row seat without removing it but for some reason i cant get the box right need some help.
sub hdc3 -18 and amp either a aq3500d.1 or an aq2200d
max dimensions are
45 ''wide
27'' high
19'' deepest at bottom to 14'' at top "angle due to back of 3rd row seats.
also shud i tune around 31 b.c of the subs fs?
subs specs
sub displacemnt is .33 if im not mistaken
HDC318
Woofer Size 18″
Fs 31 Hz
Sd 119 M2
Krm 12.686 mOhm
Erm 0.875
Kxm
Exm
Vas 109 Ltr
Cms 54 uM/N
Mmd 457 g
Mms 481 g
BL 24 TM
Qms 3.3
Qes 0.5
Qts 0.464
Sensitivity 1W/1m 89.8 dB
Magnet Diameter 8.7″
Magnet Weight 340 oz
Coil Diameter 3.0″
Coil Length 2.135″
Useable Throw 3.0″
Continuous Power 1000 W
Music Peak Power 2000 W
Mounting Depth .875″
Circle Cutout 16.50″
thank you
6 cubic feet net per sub. 16 sq in of port per cube and tuned to 36hz. Thats what I was told by DJ at Audioque. Use Exos box builder program that on the site here somewhere to design a box that will comply to those specs and fit in the area you have available.
height - 25"
width - 40"
depth (top) - 14"
depth (bottom) - 19"
port width - 4.5"
port width 2 - 7"
internal volume - 6.3-ish cubic ft (before woofer displacement)
tuning frequency - 36-ish Hz
port area - 105.75-ish square inches
16.75-ish sq inches of port per cubic foot.
CLOSE ENOUGH!
I'm not an enclosure guru, so my numbers could be off. I highly suggest someone give them a look.
You can't fix stupid
so shoot for a port with 96 in²
That number changes with relation to your net volume. You always have to find your net volume and then calculate what the sq area of the port is. A little bigger or smaller wont be noticeable.
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
