Stainless Bolt Speaker terminals
When using stainless bolts for speaker terminals, what is a good rule of thumb for how far apart placement should be? Is insulation needed?
Ride - 2006 Scion xB
Equipment:
H.U. - Kenwood KDC-X793
Amps - Memphis 16-MC2.100
Memphis 16-MC1.1100
Front Stage - Memphis 15-MCC6 6.5 Components with silk dome tweets
Subs - Memphis 15-M310D4 10" Sub (x2)
Custom box 3.02 ft3 after displacement, tuned to 37 hz
Big 3
Second Skin Damplifier
Coming soon:
Kinetik HC1400
H.O. Alt
AudioControl three.1
i do 1.5 inches usually.
i dont use any insulation
I ask because I started hearing a funny noise while playing some low level bass, so a buddy and i pulled them out... motors and coils are fine, but we noticed that I had electrical arcing between the + and - on one of my terminal sets. Those are slightly over 1.5 inches apart. Tossed some silicone around the - on both sides of the box just to make sure and now that noise is gone away. Scary to see that happening to your project!
Equipment:
Memphis 16-MC1.1100
Big 3
Coming soon:
Kinetik HC1400
H.O. Alt
3/16-1/4... not totally sure at this moment... 1 1/4" long
Equipment:
Memphis 16-MC1.1100
Big 3
Coming soon:
Kinetik HC1400
H.O. Alt
You had arcing between terminals 1.5 inches apart?
The breakdown voltage (voltage required to get an arc) of air is about 33kV/cm
You're suggesting you had 125000v between the terminals on your box? You must have one super, super badass amplifier.
10.x volts fo' life!
Well, I do have a witness... but it might have to do with the wingnuts starting to come loose and rotating the wings closer to each other than the actual bolts ... gonna replace them with some lock washers and nuts
Equipment:
Memphis 16-MC1.1100
Big 3
Coming soon:
Kinetik HC1400
H.O. Alt
  • Who's Online   1 Member, 0 Anonymous, 2330 Guests (See full list)
