Ok.. So when I play my subs loud.. I smell like.. that SMELL.. idk what it is.. it doesn't smell like burning.. but like.. idk? Inside of an appartment? It's happened on every system I've had.. I'm scared to play my 15's loud because I'm scared I'm burning the coils.. or something.. Even though It was happening to my old subs but I ignored it for like 5 months and they were fine.
Your clipping the subs
Tune your amp the correct way
heres how you do it
http://i53.photobuck...rmschartpm5.jpg
^^^This
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
Or it could be the glue getting hot if they are still new subs. but let play em for 30 mins youll get the smell then turn em down a little and do that a few days and the glue will set and no more smell
Or your running a amp the needs alot more power then your trying to run it off of . like running 3k rms on a stock and and one battery you can clip the amp and it will smell.
i just blew my brothers type r 12. on a t1000.1bd at 2 ohm at 1139rms. i didnt even have the gain up 1/4 the way and it blew in like 2 weeks. really sucks. i was hoping it wouldnt blow
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
if your box is ported smell the port and see if tahts the smell. if it doesnt smell check the amp
It's a sealed box, but I just smelled the coils on one of my blown subs.. and it smells KINDA like that.. idk.. but also.. HOW could it be clipppinggg... God the amp is DOWNN all the way on EVERYTHING.. It's only 400rms watts too .. and the sub needs 500 rms..
you could have been clipping the crap out of that amp at that gain setting.
If you think it being 1/4 way up would save you, that was your first mistake. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Just because your amp says its 400 and your sub can handle 500 dosnt mean you cant clip it. end of story your subs are POS and is your amp time for an upgrade
  • Who's Online   0 Members, 0 Anonymous, 1767 Guests (See full list)
