So I have a Rockford Fosgate T1500-1bd amplifier (amp link), and I plan on running 1 15" Fi BL. Now I am not sure I should get the Dual 2 ohm voice coil, or the Dual 1 ohm voice coil and wire it to two ohms.... Obviously, I do not want to blow the sub. Also, would I be alright if i ran reducers (1/0 > 4 reducer link) for my + and -? Or are they too close and possibly arc out?
Thank you for any and all help. :)
Ed
2003 Ford Taurus
15" Fi BL fully loaded
T1500-1 amp
Crescendo CCX525s in fronts
Kenwoods in rear
P400-4 amp
1. get the dual 2, that Fi can handle it :good:
2. run that 1/0 to a second battery in the back, then 4 guage from the rear batt to the amp.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
You are absolutely right. pick you up a little hc800 or something and run the 4 from that you can get really good for through ebay they sell 4 by the foot pretty cheap! and the FI will hand 1 ohm ALLLLL DAY! i have 1 18" at 1 ohm and it gets down and dirty!
Sound like a nice setup
As far as the reducers... just stick with the 1/0 to the amp .. Just trim the wires so there is no wire exposed when you hook it up to the amp.
you wouldn't suggest a rear batt?
Just asking because i know those power amps are power hungry little beasts.
under construction
u hate c-fizzy?
perfect.
except, you can just run a negative from the rear batt to the negative on the amp.
may i ask, do you have a h/o alternator?
under construction
u hate c-fizzy?
I do not have an H/O alternator, I am guessing it may be a wise investment though...?
2003 Ford Taurus
T1500-1 amp
Kenwoods in rear
P400-4 amp
Yea the HC800 would be good... I was only talking about the 1/0 to the amp.
oh ok,
OP, its always good to invest in a H/O alt, especially if you plan on upgrading to bigger and better things.
but for your current setup, you will be fine with just an extra battery.
Kinetic HC800
under construction
u hate c-fizzy?
