Lookin for a 2 channel 2x400 watt amp and came up with a good lookin 2x420 rms 2ch amp (oxygen audio oa1800.2) I plan on running a pair of kicker 10" CompVRs in either a sealed box or ported box tuned to 38mhz. Would this amp overpower these subs, or could it work as long as i didnt crank the volume up to 100%? im also still open to suggestions for any other good 2x400 with a reasonable price tag. Thanks!
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
that thing probably does as much power as all the other "1800 watt" 2 channels. which is like 400rms total.
get a monoblock amplifier. what model CVR's do you have? i dont want "12" CVR" i want a real model number, like dual 2 dual 4 ohm.
since when did dual 2ohm and dual 4ohm become real model numbers ??
2002 civic
2- 12in dc lvl5s
1- crescendo 3kwp ( 1 more on the way)
1- stock honda alt
4-xs d3100s
3-asa300.2 amps
6- PB 4XL's
4-PB l-3h tweets
and a bunch of other sh!t
the build
http://www.stevemeadedesigns.com/board/topic/74044-project-will-it-fit/
Youtube channel
http://www.youtube.com/user/slammedblackbish
lolol i said that because when i ask for model number, people go "oh its an alpine type r 12" and then im like ...mmkay whats the model number.
Just read that monoblocks are better sub amps and multi-channelsshud be used for mids and highs, is this true? Also, would running a split mono (both subs run in parallel) be more powerful/cost effective than just a regular 2ch?
I've went from 2 channel to monoblock, BIG DIFFERENCE, and they have a subsonic filter
I would use a multichannel amp on mids and highs, you can use them on subs, but a monoblock is much better
Alright thanks ill start lookin around... Should i look for 400rms to wire in series or 800rms to wire in parallel?
