LayneRuley Posted June 4, 2010 Report Posted June 4, 2010 Since i have two DVC subs that are around 500-600 RMS watts each. It makes sense that i just buy two mono block amps that are 500-600 RMS watts rated and basicly, one amp per sub.... and the RCA outputs, ill make a spitter or something. thats not a problem... and its cheaper cause for some ood reason 2 channel amp that gives out 1200 watts RMS is way more expensive then getting two amps..... need some help here? My old amp was clipping, need a beefier one....
Guest Posted June 4, 2010 Report Posted June 4, 2010 whyd you have to make a new thread...? get one monoblock. problem solved. i, along with a few other members, already gave you links to amps that will work for you.
bassl0va Posted June 4, 2010 Report Posted June 4, 2010 What exactly is the point of this thread? My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
Beanz Posted June 4, 2010 Report Posted June 4, 2010 ORRR Get a 1200 watt mono block HMM problem solved.. That's why they don't deliver. Yer ass better go sit along the side of the road and wait. You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
Tek Posted June 4, 2010 Report Posted June 4, 2010 U can wire up multiple subs to a mono block playboy.
LayneRuley Posted June 4, 2010 Author Report Posted June 4, 2010 when you wire multiple subs together the power is distributed, there fore under powering my subs..... right? and a 1200 RMS amp is more expensive than two 600 RMS mono block amps...
AVY_TOTIN'_SLAM Posted June 4, 2010 Report Posted June 4, 2010 NOOO... if its a mono ( one Channel ) mulitiple voice coils will lower the resistance hince apply MOAR power. Toyota Avalon 5% Tint 6000k HID JVC AVX-720 HU iPhone 3g 2 Memphis 15-MCC5 Component Sets (Front Doors) 2 Memphis 15-MC52 Coaxial (Back Doors) 1 MTX 9500 15" Dual 4 Ohm Alpine MRP-F240 4 CH. 40 watts RMS (Doors) MTX 8100.1 Add Me On Facebook.
LayneRuley Posted June 4, 2010 Author Report Posted June 4, 2010 Fialure, The RMS of a ohm load is divided between the subs. i have 400 RMS watts at 4 ohms on a monoblock and i present a 4 ohm load, each sub would get 200 watts and a 1200 RMS AMP IS MORE EXPENSIVE THEN TWO 600RMS amps...get my point? and each amp would run at 2 ohms stable. giving me the perfect power for my subs..... make sense?
AVY_TOTIN'_SLAM Posted June 4, 2010 Report Posted June 4, 2010 Fialure, The RMS of a ohm load is divided between the subs. i have 400 RMS watts at 4 ohms on a monoblock and i present a 4 ohm load, each sub would get 200 watts and a 1200 RMS AMP IS MORE EXPENSIVE THEN TWO 600RMS amps...get my point? and each amp would run at 2 ohms stable. giving me the perfect power for my subs..... make sense? FAILURE*** Just some peer editing A one channel amp doesnt divide wattage. The amp doesnt know how many speakers are applied. U can get a 2 ohm load with two 4 ohm speakers or a dual 4 ohm voice coil speaker. With your logic when I used both coils I wouldnt gain wattage. BTW 2 amps is the long run IS MORE EXPENSIVE. you will draw more from your electrical with two instead of one amp. Toyota Avalon 5% Tint 6000k HID JVC AVX-720 HU iPhone 3g 2 Memphis 15-MCC5 Component Sets (Front Doors) 2 Memphis 15-MC52 Coaxial (Back Doors) 1 MTX 9500 15" Dual 4 Ohm Alpine MRP-F240 4 CH. 40 watts RMS (Doors) MTX 8100.1 Add Me On Facebook.
