i really hope you plan on doing a double baffle? (2 3/4" boards thick)
i am using 1" mdf. is that not good? and if not can i just layer over a sheet of 3/4" overtop of the 1"?
It´s good, but i would use at least double baffle, try also to brace the box a lot!!
ama be tuned in for this one cas we just oreder some lvl5 18s for my boy cavy so ama need a lil heads up and guidance.
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
for the wall to fit i had to cut out the back seat bracing. there is a heads up
this will be my wiring
2 runs of 1/0 awg from alt to front batt + (Shurkin BT60)
2 runs of 1/0 awg from front batt + (Shurkin BT60) to rear batt + (Shurkin BT80)
2 runs of 1/0 awg from front batt - (Shurkin BT60) to chassis
2 runs of 1/0 awg from front batt - (Shurkin BT60) to motor ground
2 runs of 1/0 awg from rear batt - (Shurkin BT80) to chassis
1 run of 1/0 awg from rear batt +/- to Audioque AQ2200D amplifier
1 run of 4 awg from rear batt +/- to Audioque 4X90 amplifier
16 awg for speakers
12 or 10 awg for subs
i also started on my door pods
and have some bracing updates
Small tip, don't tune it to 33hz, too low for the AQ drivers, if u tune them that low you won't get very loud.
I would stick with recommended tuning which is around 35-38hz.
So 35hz at lowest, if u want to be louder and still hit higher bassnotes, i would tune to 37hz.
I don't know why people recomended tuning below 35hz, because that's maybe a good tuning for most drivers, but not for the HDC3's.
