i just lowered my 01 yukon, it was supposed to only a 2' drop all the way around, but ended up being more like 3- 4 drop,,iv already had to remove all the plastic from front fenders,, and it seems like every day i have to cut more and more out of back fender wells..before meade bagged the hoe, did he have this kinda trouble.......oh , and i have 305/30/26
Edited by doubleD
i had a 3/5 DJM drop and did have to cut a little bit of plastic on the driver side with those gigantic tires (305/30/26). No way i would have to do that with only a 2" drop - 2" is hardly noticable LOL
anyway, do yourself the worlds biggest favor and get the Pirelli 25 series tire if your having clearance issues......its not only the best tire i have ever owned, rides smooth and VERY quiet, it also clears like no other. FULL U-turns with no scrapage.....trust me on this one.
good luck!
Follow my Tweet (Twitter)
lol at a 30 series tire being called gigantic lol
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
How wide are your rims. Also you want to look out for the rear upper shock bolt/nut combo. The shaft of the bolt is facing towards the outside of the car and came very close to hitting my rims and tires when i put them on. Just remove the bolt and have the head of the bolt sticking out toward the outside of the car.
Jack one side of the truck in the air and take a look at wear the tire is rubbing on the fender liner adn trim that part out ( will be shiny and obviously rubbed through). Had to do some trimming when i lowered it and put the 22's on
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
i think they are 11" wide,,could this be cause its a four wheel drive ..i bought the kit from a buddy ,he said it was only 2" drop..but ive had to cut the rear bump stops in half,,the front is sitting on the bumps,,there is close to 1" of clearence from the top of the tires to the top of the fender lip all the way around..the bolts are not hitting on the wheels,,and the torsion keys are cranked to their highest point,,so it has room to go lower ,not up
Edited by doubleD
  • Who's Online   0 Members, 0 Anonymous, 1766 Guests (See full list)
