thehoe92 Build v2 Update! 3/13 iPad install!
Damn Kasey, shitty luck. Everything turns into an expensive learning experience. There's a lot of people around sac that know a thing or two about amps, hopefully someone will help you out. There's a chance that replacing the bad mosfets alone won't solve the problem either. Coulda popped a transistor, and those aren't fun to dig through.
yeah I'm not repairing it, Autosound is so they will be able to tell if anything else is bad about it
Wouldnt be thehoe92 without teh purple
damn I am havin the worst luck!
went out driving tonight and got some pictures of my 12k HID fogs and then right after my lows started flickering
I thought it was someone behind me until I pulled over and saw that the passenger side was out
took the housing off and looked at and no wires are loose so I shut the hood and both of them go off :angry:
get back on the road and hit a bump and they both turn back on again so I'm thinking something is now messed up in the ballast
I texted Gary, hopefully my warranty is still good to get some new ones because that shit is annoying!!
anyways.. before that I took the time today to run the power wire onto the drivers side
saved me a good 5 feet and I got rid of one of my fuse blocks.. don't know why I had 2 on the same run of power
voltage is now pretty damn solid at 14.8v
thank god for SecondSkin to seal that grommet up :good:
as you can tell the fogs have less blue in them then the lows but still bright as could be!
I'm doing a little research right now on Retrofitting the stock housing with some projector lens :)
Dude that sucks about your luck man, cant get a break can you. I have seen some headlights around town with retro fitted projectors for the jeep. $100 after tax. So i thought about picking me up some. Are you going to try to do the retro fit yourself?
well I guess on the bright side its finally something that I didn't do haha just bad luck in general
but yeah I'm going to pick up some bondo and some nice lens and go to work, I've got one spare housing.. the mounting bracket broke on it but I'm going to scrap that anyways in the retrofit so I could practice on that one
Cool cool, that will help focus the lights a lot more. Cops here dont care one way or the other. lol
they have some that plug into your factory bulb housing....all you have to do is some modification inside the lengs but you wont have to cutout a 3" hole and seal it up...goes from the inside and you run a nut down the backside kinda "universal" persey...also found a place that will doo the kit and install on my exploder for 300$...better than lightwurkz that said around 800$ (local place i woulda dropped them off!)
DCAUDIO
BALLS DEEP
yeah we were talking about that when you dropped off the 4k Preston
something about taking a projector lens from a TSX or S2000 and doing it myself sounds so much better than having a kit tell you how to do it
I don't know thats down the road I still owe some money on a couple things so thats the first order of business before I buy anything else :good:
HIDs look good Kasey. I threw 10k in mine and they are bright as hell.
Oh ya, got pulled over the other day for my tail lights. I guess too much of a good thing can be bad. Ha
4 - 15 Sundown Z v.2 @ 35Hz
2 - AP3000D
2 - RF Power Punch 6.5 Comps
2 - RF Power Power
1 - Kinetic KHC2000
3 - Kinetic KHC2400
Iraggi 300A
Knu Wiring
