jasonw30 Posted July 17, 2007 Report Posted July 17, 2007 what size alternator would you recommend for a t2000.1?it has a 250 amp fuse at the amp. would i have to have the same size as the fuse? 2002 nissan frontier crewcab eclipse cd2000 mb quart prem's fr&rear rf p4004
AI James Posted July 17, 2007 Report Posted July 17, 2007 biggest you can afford, better to have to much then not enoguh in this case, 200amp at least though imo
jasonw30 Posted July 17, 2007 Author Report Posted July 17, 2007 i mean the fuse is rated for peak right? 2002 nissan frontier crewcab eclipse cd2000 mb quart prem's fr&rear rf p4004
AI James Posted July 17, 2007 Report Posted July 17, 2007 yea, it should tell you in the owners manual what the average voltage drain is on it i would think
lantusx Posted July 17, 2007 Report Posted July 17, 2007 i wish i could afford a big HO alt with a 1/0 kit. :/
jasonw30 Posted July 17, 2007 Author Report Posted July 17, 2007 i kinda got a idea.if the amp produces 2500 watts at music,it will pull about 115 to 120 amps.so i believe 180 to 200 amp alt will work. 2002 nissan frontier crewcab eclipse cd2000 mb quart prem's fr&rear rf p4004
E a r t h Posted July 17, 2007 Report Posted July 17, 2007 I believe RF recomends an alt of 125amp minimum for the T20001bd
jasonw30 Posted July 17, 2007 Author Report Posted July 17, 2007 I believe RF recomends an alt of 125amp minimum for the T20001bd thanks,bro. 2002 nissan frontier crewcab eclipse cd2000 mb quart prem's fr&rear rf p4004
dmanson Posted July 17, 2007 Report Posted July 17, 2007 for the T20001bd it is recommended that a 150amp is the minimum alternator size, then once you factor your amp for you mids and highs you'd be around a 200 amp alternator. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
