1st. What's the big difference between PVC and Aero?
2nd. Whats the big difference between using a HUGE port like the ones where you can fit a kid in, and smaller port that you could fit like a house phone in...
3rd. Aero Squaro etc... Rounded edges with ports, why? What does it do?
Basically, all the info I can get on ports...
:pardon:
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
I can answer number 1, the Aero comes with pre-made flares, pvc does not have flares. Without the flares, you can get turbulence and port noise. However, you can make flares for pvc, its just extra work.
I'll take a stab at number 2, I know that if you make the port too small, you will get port noise, like a whooshing sound as the air travels in and out of the port. As the port gets bigger, that noise goes away. But I'm pretty sure, as the port gets bigger, you get a narrower response (more of a peak), where as a smaller port can give you a flatter response (less of a peak).
Rounding the ends of a square port does the same as having flares on your aero/pvc ports. It reduces port turbulence and noise.
97 Maxima SE
Bunch of shit going in, check out the build
aero ports are preformed and bought. you see people using pvc as a cheaper alternative. PVC may also induce port noise depending on install.
2 it has to do with port area. a larger box typically shou;ld have more port area. the squareo port as you call it has the ends rounded for increased air flow. it can be done a multitude of ways. kerf cuts is one way.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
So if I use a router and round off where I put a PVC for a port, it will be an aero?
What is a kerf cut?
boxs with those huge ports are fart boxs aka burp boxs. Designed to play a certain freq. loud as hell
So like those people running 2 12's in a CRX with multiple big ass aeros coming out of it.
A kerf cut is a method of bending wood.. Google's your friend
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   0 Members, 1 Anonymous, 2004 Guests (See full list)
