Alright once u first get in my car it drives perfectly but after about ten mins ( citydriving) when I turn it makes this loud humming noise an I can feel it in the steering wheel. My power steering fluid is too full, like it says to not overfill an whoever did last oil change over filled it. But I doubt that's the problem. It's proably the power steering pump right?
Sorry for long post an thanks for all replys
Is it vibrating really bad or just slightly? Idk if there would be a difference, but my mom's santefe was shaking real bad even when driving straight and it was because of the pump. Her belt also started squeeling bad too. I'd imagine that it's something with your belt, or bad pump, could also be the fluid it has a full line for a reason. I know nothing about stuff like this so don't take my word :pardon:
Edited by vengfuldev
Start out boxy, shape as you move along.
Dc Audio
Team Fur
sounds like its either your power steering pump or rack and pinion is going out. idk wat kind of car you got but if its got rack and pinion steering id say the rack is going out
Did you use power steering fluid or ATF?
EDIT: Get a turkey baster and drain it till it's at optimal level too...
Too much or too little oil can lead to problems.
Edited by EricM9104
I belive I use power steering fluid in the power steering. An ok il get some out to make it not overfilled, I talked to my dad an he said tht it's my power steering pump going out
That'll happen when you use actual power steering fluid in a Ford power steering pump.
