My cousin gave my his Hifonics BX2200D it went straight into protect with only the ground, power, and remote.Is this amp worth fixing to keep, sell, 0r should i just get a used MB Quart discus 2k?
Edited by premierdime
whats a constant? i assume you mean power (12v), remote turn-on, and ground.
did he say what happened right before it went into protect for him? it could be something as little as a single copper strand of wire got into the amp and is shorting something out, or as "big" as showing the amp low voltage and smoking some components inside
it is called constant. meaning there is always power running to it. also knows as "hot"
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
take it to repair shop and have them test it for you, it may be an easy inexpensive fix. if so let them repair it if not your out a couple of bucks for a bench test, you got the amp for free.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
if your on a tight budget in my opinion it would be better to see what's wrong with it and make a decision based on what you find out. most shops charge a bench fee and will add that to the cost of the repair should you decide to get it fixed. so if the repair ends up costing you 100.00 bucks lets say, your still ahead of the game versus kicking out lets say 250 or 300 on another amp.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
