HELP FROM THE BEST
is this semi-right for 2 15in re se subs off of 1200 watts
stats
gross volume:8.69 cubes
port volume:.75 cubes
physical port length: 14.25
port bends: no
baffle displacement:0.0 cubes
port range: 96- 128in
port area: 60.00in
port area per foot:7.50in
net volume: 8.00 cubes
tuning frequency: 30.73hz
box dimensions
21h X 41w X 21d
port dimensions
15h X 4w X 15L
lmk if its ok
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
box is too big..
port is too small
you want around 6.5-7 cubes for two 15s
you also wanna stay inbetween the reccomended port area..
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
box is too big..
port is too small
soo how do i figure out the port area..
Box seems pretty big to me for two 15's. I would probably do 6 cubes.
so when they put the spects for optimum use where do they get the spects not questioning ur judgement just looking for imfo and i thank u sir
The difference is when you put multiple subs in a common chamber you can shrink it down some because it's shared space. As a general rule of thumb most 15's work well in 3.5 cubes ported.
sooo round about 7 cubes and say 112in of port area would make a good box..
port area is the width of the port times the height make your port wider and its probably gonna need to be alot longer in order to get the tuning you want so mess around with it some more i'd say 120square inches of port minimum for 2 15's i'd say try making your port 7in wide.
  • Who's Online   0 Members, 0 Anonymous, 1370 Guests (See full list)
