Cashdollar2009 Posted June 17, 2010 Report Share Posted June 17, 2010 Quick question, I am putting two runs of 2/0 from my front battery to my rear battery bank. I understand the placement of the fusing along each line, but was curious as to the size. I am planning to run a Crescendo 3k @ 1-ohm for 3000rms. The fuseholders shipped with 150 amp anl fuses. Would it be proper to just run 150 amp fuses in each holder on each line? I understand if I were trying to squeeze 3k out of one run of wire it would be drawing too much current theoretically, but could I divide the load out between the runs? Thanks ahead! Quote 1997 Chevrolet Cavalier Two 12" DC Audio XL M2'sCrescendo Audio BC5500d Current Scores: 150+ out the Trunk On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not. Link to comment Share on other sites More sharing options...
Kandrew279 Posted June 18, 2010 Report Share Posted June 18, 2010 Quick question, I am putting two runs of 2/0 from my front battery to my rear battery bank. I understand the placement of the fusing along each line, but was curious as to the size. I am planning to run a Crescendo 3k @ 1-ohm for 3000rms. The fuseholders shipped with 150 amp anl fuses. Would it be proper to just run 150 amp fuses in each holder on each line? I understand if I were trying to squeeze 3k out of one run of wire it would be drawing too much current theoretically, but could I divide the load out between the runs? Thanks ahead! Ok, so 2 runs of 2/0 to the back batts, then 2 runs from those batts to the crecendo? You shouldn't need 2 runs to the amp, I believe the amp terminals are only designed for 0 gauge, and a single 300a fuse. Quote Link to comment Share on other sites More sharing options...
Gotloud555 Posted June 18, 2010 Report Share Posted June 18, 2010 150 fuse for 2/0 guage wire? Quote Link to comment Share on other sites More sharing options...
Kandrew279 Posted June 18, 2010 Report Share Posted June 18, 2010 (edited) 150 fuse for 2/0 guage wire? yes. 150 on each. Edited June 18, 2010 by Kandrew279 Quote Link to comment Share on other sites More sharing options...
STEvil Posted June 18, 2010 Report Share Posted June 18, 2010 should be ok..... but might want to get a pair of 200's in case they blow. Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
skittlesRgood Posted June 18, 2010 Report Share Posted June 18, 2010 that will work with 150amp fuses. BUT you have this nice thick 2/0 wire that you are putting a very small bottle neck on. i would get a 300amp just for better current flow. Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people. Link to comment Share on other sites More sharing options...
TeejayBee Posted June 18, 2010 Report Share Posted June 18, 2010 just do 300a fuse on each line and call it a day Quote Link to comment Share on other sites More sharing options...
kandiman71874 Posted June 18, 2010 Report Share Posted June 18, 2010 actually, if you are doing it correctly its 2 fuses per run, one after the front battery and one right b4 the rear battery bank on each front to back run. Doing this will help prevent electrical fires in the event that the wire would get rubbed through anywhere and short to ground. Quote Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites Link to comment Share on other sites More sharing options...
Cashdollar2009 Posted June 18, 2010 Author Report Share Posted June 18, 2010 actually, if you are doing it correctly its 2 fuses per run, one after the front battery and one right b4 the rear battery bank on each front to back run. Doing this will help prevent electrical fires in the event that the wire would get rubbed through anywhere and short to ground. Starting battery===Fuse on each============Fuses again==Rear Batt Bank--Fuse---------Amp. I understand placement, and will be purchasing a few 300A this weekend, but wanted to know how well the 150's would hold up for the time being. Thanks guys! Quote 1997 Chevrolet Cavalier Two 12" DC Audio XL M2'sCrescendo Audio BC5500d Current Scores: 150+ out the Trunk On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not. Link to comment Share on other sites More sharing options...
finkster Posted June 18, 2010 Report Share Posted June 18, 2010 Depending in who makes the fuses, they may blow or may not. Theoretically if you're making over 3kw they would blow, but music is dynamic. Definitely upgrade to the largest fuse possible for 2/0. 300 is fine also. Quote DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living Link to comment Share on other sites More sharing options...
