Fusing multiple runs of 2/0
Quick question, I am putting two runs of 2/0 from my front battery to my rear battery bank. I understand the placement of the fusing along each line, but was curious as to the size. I am planning to run a Crescendo 3k @ 1-ohm for 3000rms. The fuseholders shipped with 150 amp anl fuses. Would it be proper to just run 150 amp fuses in each holder on each line? I understand if I were trying to squeeze 3k out of one run of wire it would be drawing too much current theoretically, but could I divide the load out between the runs? Thanks ahead!
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
Ok, so 2 runs of 2/0 to the back batts, then 2 runs from those batts to the crecendo? You shouldn't need 2 runs to the amp, I believe the amp terminals are only designed for 0 gauge, and a single 300a fuse.
should be ok..... but might want to get a pair of 200's in case they blow.
Hammerdown... 1%
that will work with 150amp fuses. BUT you have this nice thick 2/0 wire that you are putting a very small bottle neck on. i would get a 300amp just for better current flow.
actually, if you are doing it correctly its 2 fuses per run, one after the front battery and one right b4 the rear battery bank on each front to back run. Doing this will help prevent electrical fires in the event that the wire would get rubbed through anywhere and short to ground.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Starting battery===Fuse on each============Fuses again==Rear Batt Bank--Fuse---------Amp.
I understand placement, and will be purchasing a few 300A this weekend, but wanted to know how well the 150's would hold up for the time being. Thanks guys!
Depending in who makes the fuses, they may blow or may not. Theoretically if you're making over 3kw they would blow, but music is dynamic. Definitely upgrade to the largest fuse possible for 2/0. 300 is fine also.
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
  • Who's Online   0 Members, 0 Anonymous, 1830 Guests (See full list)
