Kandrew279 Posted June 19, 2010 Report Posted June 19, 2010 no... because of the way a speaker works. The voicecoil essentially becomes a magnet as a charge moves through it.... making it repel/attract to the stationary magnet- hence movement. The magnetic force on a coil has to do with amperage, not voltage. Meaning some watts could be stronger/weaker when it comes to moving a sub. What are these "strong watts" and "weak watts"??? Consider this scenario, 3 amplifiers, (1) 10v with 10a (2)100v with 1a (3)1v with 100a Which of these amplifiers will produce the loudest sound with their (heres the tricky part) appropriately matched woofer? *HINT* all of these are putting out 100 watts
HHR Ed Posted June 19, 2010 Report Posted June 19, 2010 Watts are not just watts. Not all similar powered amps are created equal. Depending on the impedance and wiring scheme of your woofers, either more voltage or more current may be beneficial. You can indeed have actual 1500w going to your woofers be louder than another amp doing the same exact power. And in MOST cases, wiring voice coils in parallel would be louder than wiring voice coils in series even if the final ohm load is the same, and actual power is equal. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
Red-navi-916 Posted June 19, 2010 Report Posted June 19, 2010 Stront watts are your RMS watts and weak watts are your PEAK. WattS haha run rms and ull be strong run peak and say bye bye to your stuff BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
Kandrew279 Posted June 19, 2010 Report Posted June 19, 2010 All watts are created equal lol. There are "different types of watts" ie. strong, weak, fat skinny. although a certain wattage can be composed of an infinite amount of voltage and current combinations. A watt is a measure of POWER, not force, not energy. If 2 amps of different brands are both putting out the same wattage, and paired with subs of equal sensitivity, then since they are both putting out the same power, the subs will produce the same sound, even if the amps aren't putting out the same voltage
HHR Ed Posted June 19, 2010 Report Posted June 19, 2010 All watts are created equal lol. There are "different types of watts" ie. strong, weak, fat skinny. although a certain wattage can be composed of an infinite amount of voltage and current combinations. A watt is a measure of POWER, not force, not energy. If 2 amps of different brands are both putting out the same wattage, and paired with subs of equal sensitivity, then since they are both putting out the same power, the subs will produce the same sound, even if the amps aren't putting out the same voltage Nope, not true. After hundreds and hundreds of tests. Myself and dozens of other top SPL guys have found differences with the same power, but different volt to current ratio. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
InfiniteRuckus Posted June 19, 2010 Report Posted June 19, 2010 i love these technical discussions. i wish i had something useful to add
rusty959 Posted June 19, 2010 Report Posted June 19, 2010 I think the difference is remembering ohm's law... (others have sorta touched on this) amperage(A) as you say is what creates the magnetic force. A = V * R. What of those is "constant"? The R. (obviously not completely, but the amp can't change it directly) So how is A increased? By increasing V. There is no way to have "bigger" amps as you say. An amp is an amp. As stated, some of the big differences between amplifiers is the quality of signal/reliability/efficiency. Cheap amps will often have cheaper parts. 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959
jake1993 Posted June 19, 2010 Report Posted June 19, 2010 Nope, not true. After hundreds and hundreds of tests. Myself and dozens of other top SPL guys have found differences with the same power, but different volt to current ratio. i wanna see some of the test results (not cause i dont believe you. I just wanna see the turn out) ... i wanna see the difference between 2 amps that "do" the same power Jacob Sigmund 1 dc level 4 m1 18 1 audiopipe ap1500 2 runs of knu 1/0 Alex Bennington" <[email protected] ^^^ want one one email this guy he will hook you up!
rusty959 Posted June 19, 2010 Report Posted June 19, 2010 Nope, not true. After hundreds and hundreds of tests. Myself and dozens of other top SPL guys have found differences with the same power, but different volt to current ratio. Where are these volts and currents measured? I am assuming the voltage is measured on the speaker side of the amp and the current is measured on the battery side? 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959
HHR Ed Posted June 19, 2010 Report Posted June 19, 2010 Where are these volts and currents measured? I am assuming the voltage is measured on the speaker side of the amp and the current is measured on the battery side? No, we are talking about output power, everything is on the speaker output side. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
