Wiring XL 18 to AQ 2200
The XL is dual 2 ohm. The aq doesn't have a internal crossover, so to allow the XL to see 2200 wrms would I... Bridge + to + and - to - on the amp. Then run a positive to positive and negative to negative on the DVC of the sub. Run the positive of the sub to the bridged positive on the amp and the negative of the sub to bridged negative of the amp?
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
If you have 4 out puts on your amp. Two pairs of (+) and (-) then your amp should paralel that so you can just run four wires ( I use 8 gauge) to each post on the sub and then to the amp.
I thought it was possible to just run 4 wires two + on the amp to the two + on the subs and same for the negatives. Wasn't sure though. Thanks guys
  • Who's Online   0 Members, 0 Anonymous, 967 Guests (See full list)
