So I am considering buying a 95' bronco, when I test drove it I could smell it burning oil. But there wasn't any smoke being blown out. Will the problem escalate(to the point of rebuilding the top half of engine)? Or should I buy it?
Thanks for all the input
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
if its burning oil, it will only go down hill from there, and you could be looking at rebuilding the bottom end also if it needs rings.
is it burning oil throught the exhaust or on the exhaust from an oil leak to manifold is the ?
check the valve cover gasket.
make sure the exhaust isn't smoking blue/white...
run a compression check
test drive it
