Under powering VS, leaving bass knob down
Ok so im not the smartest man on earth , so im here to learn... I seen all the time ppl talking about under powering can cause damage.. Which in a since can be very true...Tho whats the difference in under powering the sub and have the right amount of power but leaving the bass knob down??? All in all its still being under powered.. right?
2002 civic
2- 12in dc lvl5s
1- crescendo 3kwp ( 1 more on the way)
1- stock honda alt
4-xs d3100s
3-asa300.2 amps
6- PB 4XL's
4-PB l-3h tweets
and a bunch of other sh!t
the build
http://www.stevemeadedesigns.com/board/topic/74044-project-will-it-fit/
Youtube channel
http://www.youtube.com/user/slammedblackbish
you cannot hurt a sub by under powering it. ever.
it is clipping that leads to killing a sub and most of the time clipping is caused because the amps being used do not make enough power for the sub, so the user turns the amp beyond the point of clipping without knowing it.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
x2
Follow my Tweet (Twitter)
So that means if the amp does not move your sub you then turn the gain up to max which then the amp clips. Its then called under powered. Get a bigger amp turn the gain down get a better stronger sound plus long life for your subs.
no its called clipping. in reality it is making a lot more power than it is rated for but it is nasty dirty power.
theoretical example. 1000 watt amp 1000 watt sub. turn gains up way too high and now you have 2700 watts going to the sub. on top of the grossly overpowering, the sub now has to deal with square waves which limit the cooling capabilities of the sub.
ie burnt sub.
Edited by IH8PunkRok
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
x3
Current
Ford F350
Alpine IVA-W505
2x Diamond s600
1x Diamond S400
2x RF T1500-1BD
1x RF T600-4
2x AA Havoc 12"
DC Power 230XP
1/0 throughout
Up Next
95 2dr Tahoe
Head Unit= Alpine IVA-W505
Components= 2 Diamond S400, 2 Diamond S500, 2 Diamond S600
Woofers= 2 10" Diamond Hex, 2 12" Diamond D9
Amps= 3 RF T1000-4
Processor= 2 RF 3sixty.2
Subs= 4 18" AA Mayhem
Amps 4 RF T2500-1 BDCP
7 XS Power D3100
3 DC Power 270+
Thanks for the fast responses... I kinda figured it was the clipping that caused the issue, but everyone seems to toss the under powering thing out there.. Me personally i dont have that problem, i usually have more power then needed..
2002 civic
2- 12in dc lvl5s
1- stock honda alt
4-xs d3100s
3-asa300.2 amps
6- PB 4XL's
4-PB l-3h tweets
the build
Youtube channel
Keep this in mind a bass knob is only a remote gain control its garbage. Set your gain and leave it.
Not exactly its a remote gain that has a certain frequency with a certain slope its adding gain at a certain point i.e. RF is 43 HZ with i think a 12 db slope
Current
Ford F350
Alpine IVA-W505
2x Diamond s600
1x Diamond S400
2x RF T1500-1BD
1x RF T600-4
2x AA Havoc 12"
DC Power 230XP
1/0 throughout
Up Next
95 2dr Tahoe
Amps= 3 RF T1000-4
7 XS Power D3100
3 DC Power 270+
Im confused on how so many people can think that under powering can damage subs. Cause if this was true every time you turn the volume down it would blow your subs right?
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
clean power VS. dirty power
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
  • Who's Online   0 Members, 0 Anonymous, 694 Guests (See full list)
