can underpowering subs make them sound distorted? my situation is i just finish my new box, i have 6 dc level 3 12's, and when i played them they sounded a little distorted on lower frequencies. keep in mind they're only getting maybe 300 watts a piece right now.
6 dc level 3 12's
digital designs Z1A
pioneer h/u
4 sets of rockford 6.5's
crunch 1600.4
Mechman 270a alt
kinetik hc2400 (soon to be xs power d3100)
xs power 3400 (under the hood)
lots of 1/0
Your gain is up too high or your deck is turned up too much.
try adjusting one or the other to see if distortion goes away.
Too many projects, too little time...
x2
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
i do believe it is the hu. i messed around with it a little bit and if i turn it down a little it goes away. but just for the question's sake, is it possible for distortion to be caused by underpowering?
6 dc level 3 12's
digital designs Z1A
pioneer h/u
crunch 1600.4
Mechman 270a alt
lots of 1/0
doubt it... most likely clipping.
I'll change that "doubt it" to no.
If it did, your sub would sound distorted every time you turned the volume down.
EDIT: READ
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 0 Anonymous, 1803 Guests (See full list)
