u are?
lol
iight well ill give u those T3s cross overs and that lightingrockford audiofosgate 4chan... which then u dont need the cross overs lol...
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
lol, you guys sound married...... :rofl:
and come on by. you both know my number :good:
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
  • 4 weeks later...
wee bit of an update.....
all 4 amps mounted.....
and EASY to adjust from the drivers seat lol
first time the big guys ever had power to them. 5200 watts rms :yahoo:
still have not yet found new pillars to place these things, crammed in dash until then
and still missing some speakers.....will have to buy 6 new pairs i guess.....
but still look ready to reproduce some tunes!
the rest of the rca's, splitters, and rca volume/bass control will be here soon. hope to be battery shopping soon.
7" BDS HC lift kit
did you figure out your pre-out voltage after its going to be split up amongst 4 different amps?
I think Justin might have a line driver for sale
Wouldnt be thehoe92 without teh purple
ahhhhhhh myyyyyyyy godddd....well these doors r simply amazing man..what all did u have to use for the foam an were did u get it..i would like to use this idea if u dont mind??
there are different thicknesses available and sizes as well at home depot. in the insulation area. (is designed for use on outside of house as a wrap) i just sprayed 3m adhesive on the panel and the foam and stuck where I wanted it. you need to seal the foam with a foil tape or something of that nature as FIBERGLASS RESIN WILL EAT IT!!! :angry: found out the hard way, even after being warned. but easy to sand/shape and light as hell.....
I have separate outputs for front, rear, and sub. alpine deck....think I still need one? front goes to a 6410, rear goes to other 6410, and sub goes through first 2610 as master/slave to other 2610......
just realized, sending 2 channel rca's to 4 channel amps. so already split there. what does justin have any link to one like it?
Or you could buy a maxxlink, I just bought one today :)
link to the one you bought? ppppplease. may be another mother in law pic for ya!!!
7" BDS HC lift kit
yeah I don't know how you did that unless you did what I told you for the front and rear and used the pass thru..
sub amps if its a master/slave deal then you are good because you only need to supply one amp with the pre-out voltage to get it to work
or just help logan out :rofl:
