Official Green Monster Xterror
that is soo nice :) man, i cant wait to hear it :)
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
quick question for you what ohm are your xls and what do you have your m3s stapped at. i hooked up my 4 xl 18s d1.4s yesterday and i have them strapped at .7 shit pounds but my slave amp goes into protect on certain songs when im nailing it. if i wire it up to 2.8 do u think ther will be alot less output. i dont wat to fry my m4. what do u think
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
For daily they are strapped @ 1ohm (.5ea amp), plays fine all day long. I tested them strapped @ .25 (.125ea amp). Worked fine but I had to roll the volume up to full tilt. Burping @ full tilt the amps would protect.
i ohmed at my amps and got a reeding of .4 to .5 so amps are seeing half that. it plays most music fine. should i wire them up? i know out put will go down but how much is the question. dd says 2ohm minimum and if i do u think i could blow one? also my voltage drops bad at idle 11.5 im waiting on a 3rd alternator then i should be fine
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Its really hard to say. Do the amps play for a while before going into protect? Or is it right away? Everything really depends on why the are protecting? I couls be thermal protect from getting to hot. I have seam them run hard for hours @ .25ea for several hours with no issues. I also depends on voltage and final load after rise. If you say its certain songs your load could be dropping very low causing the protect. Wiring it up high wond hurt the amps just might make things not as loud.
Liez.!!
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
I know what it is!!!! It's big long and shiny :). Imma take it to the beach and use it as a surf board :)
can't wait for some big power!
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
