Hey guys,
I know its been a while since ive been on here, but I have a question. Ok so I recently installed a system in a 1998 ford F-150. I did the power wire on the right side (passenger) signal on the left(driver). I made sure everything was good all tight and all. So about a week later I get a call that some of the gauges take longer to come on the dash like the odometer and all. I didn't know what it was figured it was no big deal. Then now I hear that the 4 wheel drive wont switch. I hear its probably something electrical with the switch. Is this something the system did? how would I go about fixing something like this?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
all the fuses are good too
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Hey guys,
did you mount any amps to the floor?
God damn its hot today. My balls are stuck to my leg.
no but i did ground the amp straight to the floor
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
it could be the vibrations making things go bad. Factory head unit or aftermakret?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
aftermarket
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
any other suggestions?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
I meant to ask if you grounde it under the seat. I saw a guy install an amp under the seat of a 2001? Ranger with 4 wheel drive. Amp got mounted under driver seat. Transmission acted up. Dealership claimed screw was run through wiring for transmission. Never found out for sure.
grounded it behind the seat just drilled and cleaned her up with a dremel so idk
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 1747 Guests (See full list)
