you missed the most important part...when neo heats up it losses force that never comes back
never heard that one before
Team Soundstream
Team Xs Power
Team Secondskin Audio
Team Mechman
did not know that.... how hot roughly before it looses BL
R.I.P!
(Nov-29-2009)
92 explorer
current build
Neodymium magnets are the greatest of the rare-earth magnets. The strength of their magnetic field at the poles ranges from just under 1 tesla (T) to as high as 1.5 T. Because they are cheap - you can get a small neodymium magnet for a single US dollar (USD) - these magnets are used quite frequently in industry and among hobbyists and dabblers. For example, every computer hard drive has a small neodymium magnet which helps direct the needle that reads data. They can also be found in high-end speakers and science classrooms around the world.
One of the only downsides to the neodymium magnet is that its magnetic field loses some intensity when temperatures are too high. This precludes their use in electronics applications in which a lot of heat is generated. There exist versions of the neodymium magnet that perform better under higher temperatures, but in these cases strength must be sacrificed.
Neodymium magnets are incredibly strong. A neodymium magnet the size of a quarter can suspend a piece of iron weighing dozens of kilograms. Two such magnets snapping together at the wrong angle can pinch your skin and draw blood. Neodymium magnets the size of a golf ball can be extremely dangerous, wiping credit cards, sending metallic objects flying, and potentially causing bodily harm if used without care.
Bingo James ;)
That multi magnet array woofer towards the middle of the thread doesn't look like neo at all, a shit load of ceramic magnets instead
The first motor is the Focal and/or MCM branded woofer with the array, and they were still ferrite.
I know one company out here doing , thinking of doing a monstrous neo motor for SPL to compete with another big company, but not saying anything about it
Cooling is the best part of using arrays, for the magnet, and the coil
I believe that big one is a Shocker.
96 IMPALA SS
Pioneer DEH-P8600MP H/U
Pioneer TS-C160R 6.5"
Pioneer TS-D690R 6x9"
JBL GTO755.6II
Stinger spdh-10 cap
100sqft. Fatmat
AQ 3500d
18" FI BTL 7cuft 35Hz
You sir are correct it is a Shocker Apokalipse
¿ǝɯɐƃ ǝɥʇ
