I am unsure why, but I cannot access the forum while at home. I have not changed any settings adn I have used 3 different browsers, and it will not allow me to access the forum. Tells me the site is either busty or i have a firewall blocking my connection, but I am ont he site now at school and called my wife to see if she coudl get on and it had same problem, and I do not have a firewall so I know that is not the issue.
Is anyone else having this problem?
Did my IP get blocked for any reason?
i highly doubt it was blocked without your name being banned. are you sure you dont have a firewall?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yea i am quite sure i have no firewall. The OS firewall it shut off and i have no virus software at all (havent installed it since I upgraded to windows 7) I had just got done replying to a post, and then received a message from forevrbumpn, went to reply and all of a sudden it was down, and i havent been abck since while at home
as i thought it is something to do with my ip address
i am using a proxy and i can access the site from home now, but if i use my normal ip i cannot access the site, this is the only site that does this, so i am unsure as to why it is doing this
i do not see my isp banning this site as there is nothing wrong with it, so sadly i may have to use a proxy every time i want to go here, which sucks because this is about the only thing i check on besides email on the internet
try this from your home computer
go to start run type in cmd and hit enter
type this command
ipconfig /flushdns
that will give you a clean slate for the site as far as DNS entries go. Ive found taht helps quite a bit at work but may not here.
Have you ever had a screen name banned here? Be honest. I can't help if i dont have all the details.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
nope, i have never been banned or even had warnings for anything
ive always been kynto on here
my IP addres to my knowledge has also always been the same
did the flush dns and it still doesnt work without a proxy, so i can only think its my IP address
any chance a mod may have set it to ban an ip starting with a certain number or containing a certain number
hmm, werid, try deleting your cache and cookies and such
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
dunno but ill check into it for you.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
thank you
i have already tried clearing cache and cookies, even installed some security software, as i had none previously, (just hadnt reinstalled since OS upgrade) and had no problems
now yahoo.com actually started doing same thing this morning, this is weird
did someone stealed your internets?
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
  • Who's Online   0 Members, 0 Anonymous, 1747 Guests (See full list)
