4 Ascendant SMD 18's, 36kwrms!! - teamSPB Project D*FN U...NEW UPDATES! 9kwrms PER SMD!!
Inch thick MDF added
All 4 sorted
Test fitted
At this point, we were decided on running 4 SPL Dynamics D5's...however, due to a supply problem...we are considering a few options...however, the amp layout will remain the same
For a little while, the amp rack remained like this
Ignore the nasty cabling LOL! Everything was lashed in to make sure it all worked ok and to encounter any potential problems we will see at full power....had a ROCK solid power supply before the batteries were sold though!! 3 x XS Power D3100s!!
Midrange mount removed
teamSPB
Remaining parts of the back of the box were carpeted to - although these bits wont be seen once everything else is fitted and the front panels are on etc...I wanted to put carpet onto the mounting surfaces just to make sure there were no vibrations etc
SPL Dynamics D5 was moved up
Remainder of the side panels were made
Carpeted
Some of you may have noticed I complain of voltage issues night and day...in the next picture you will see why PMSL!!!!!!!!!!!
And a rather nice pic of the S6002's
Think it might be time for some TL scores now that everyone knows my power supply and problems LOL!
teamSPB
Testing when the subs were brand new...Stiff as anything...and no EQing or gains setup
Power approx 2k with voltage into the 11's
Sealed
20 142.5
21 144.3
22 145.4
23 147.3
24 148.3
25 149
26 149.8
27 150.1
28 150.5
29 150.8
30 150.7
31 150.5
32 150.1
33 149.8
34 149.7
35 149.7
36 149.4
40 149.7
45 149
Ill be doing more testing when I get the TL back as the subs have softened up, and its ALOT louder now we have had time to mess around with things! STILL on a CRAP power supply to! The Halfords battery is holding up LOL!!!
Mic on screen, door open results coming up
teamSPB
Mic on screen, drivers door open
20hz 146.4
21hz 147.6
22hz 148.5
23hz 149
24hz 149.5
25hz 149.9
26hz 150.2
27hz 150.4
28hz 150.8
29hz 151.3
30hz 151.6
31hz 151.7
32hz 151.9
33hz 150.9
34hz 150.8
36hz 151
38hz 151.3
40hz 151.3
45hz 150.6
A few days later ~30hz scores became;
28hz 151.4
29hz 151.9
30hz 152.7
31hz 153
32hz 152.8
33hz 152.8
34hz 151.6
Cant wait to test what its like now...should have gained a small bit here and there..howmuch though, I have no idea until we test again...
teamSPB
