Stinger voltage meter install
Just got my voltage meter and i was wondering what the best place to read the voltage from? just to the front battery? and what wire from the igniton to i wire the blue wire to?
Honda Accord 4 Door
Current System -
(2) 12'' Mtx Thunder 5500's
(1) Alpine Mrp-m1000 @4Ω
(1) Pioneer Deck Deh-3500
(1) American Legacy 1.0 Farad Capacitor
(1) Stinger Voltage Meter (Blue)
Big 3 Knu 1/0
Box 3.4^3@37hz
there or straight from the amp alot of people prefer so they see what the amp is seeing. blue wire is remote so hook it to the remote input on your amp or from the headunit
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
will hooking it up to the remote wire on the amp be about the same as having it on the power wire?
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
You hook the turn on for the gauge to the turn on for the amp.
From what I've read, it doesn't really matter that much where you connect. In a good charging system you should only have a few tenths of a volt difference.
That said, I'd connect to where the amp is. That's where a voltage reading really matters IMO.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
if you are talking about hooking up the volt meter blue wire to power wire then no because it will always be on even when the car is off and will eventually drain your battery
votl meter has three wires..
red to power on the amp
blue to the remote turn on, on the amp
black on ground on amp
:good: amp turns off,volt meter turns off too
Where did you go about getting your voltmeter, i have looked all over and the Blue one is much more then the Red one.
take baby steps, u cant do it all at once unless u have a roll of 100's big enough to choke a donkey
1998 Chevy Venture "Swagger Wagon"
Kenwood Excelon KDC-X994 Headunit
3 15" Alpine Type R's in seperate T-Lines
1 RF T1500-1bd for 2 of the 15s
1 RF P1000-1bd for the single 15
3 sets of Hifonics Zeus ZXi6.5C Components( 1 more set to come for Front stage)
1 Hifonics HFi100.4 4-channel amp
Stock alt for now (DC HO SPL 400A when funds come in,currently working on buying this)
Stock battery and one Optima Redtop for now (looking at XS batteries)
3 15" Alpine Type R's (aka Swagger Wagon Build 1.0)
Swagger Wagon Build 2.0
Youtube Videos
yeah for some reason they where $18 shipped for a month or two and now they are way more expensive....
ebay is where i got mine at
It really makes no difference where you install it at. It won't run down your battery. Volt meters draw very little current, much like a car clock or alarm. Like others have noted, if you have a solid electrical you will suffer little to no voltage drops across the circuit. If you have a bad electrical circuit then you really have no reason even installing a volt meter. Just install it where it is most accessible.
The King.
  • Who's Online   0 Members, 0 Anonymous, 2669 Guests (See full list)
