"Generator" fuse keeps blowing. need help badly
One night i had my system turned up fairly loud. evidently i blew a "generator" fuse, this was in my fuse box and comes stock with the car.
what this did was keep my alt from charging the battery, at all.
now there are a fair amount of people who have mustangs and more power than me. why is it i blew this little 20 amp fuse?
does it have anything to do with the fact that all my power wire is attached to the distribution block on the fuse box under my hood?
this really sucks because i cannot turn it up to loud at the risk of blowing that fuse. what can i do? why does no one else have this issue?
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
blew the fuse aain tonight but with a couple differences
1. system was turned down
2. a/c was not on
i drove it earlier today with no problems but tonight it blows.. makes me think it may be the lights but i am not sure.
does anyone have any idea what would make that fuse blow? i need help bad
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
i have determined the problem is related to engine load. if i am getting on it (3k+ rpms) the fuse will blow
i measured the resistance of a couple things in comparison to my stock alt and the resistance is much lower on my HO
so is my alt bad?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
i have been conferring with my dad and he has told me that this fuse is attached to the field wire which is what tells the alt to make more power or not. he says something is demanding more current than usual and that means more current is fed through the field wire causing it to blow.
i do not believe it is a short circuit. after putting my stock pulley on my HO alt, my rpms could go to about 4-4.5k before the fuse would blow. this tell me for sure that it has to do with the alt
my dad also seems to think that if we upgrade the field wire to a larger gauge it might help. honestly im not sure because this "field" concept is above my head at the moment.
I need some help, some insight as to why this is happening. even better i need to know how to stop it. my stock pulley on this alt is keeping my voltage at about 14.2 which is not where i want it.
please help me someone
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
what size fuse is your amps? If they're like a 60 or 8 0 watt amp fuse its demanding to much from that little 25 amp fuse. The solution: disconnect it from the fuse block and install an equil size relay or breaker it'll make your life alot easier. correct me if Im wrong anyone
Edited by blackrosetiger
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
this fuse isnt on my amplifiers. it isnt the big power wire from my alt to my amps that is the problem.
it is a control wire that is fused in my power distribution box that is labeled generator
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
maybe lik your pops said that wire may need to be larger to suppoet that bigger load?
quite possible
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I'd bounce these ideas your pops had with other Mustang owners that have high current systems to ensure it is this one wire/fuse. Maybe a Mustang forum may be of service to you.
thats an idea
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 1666 Guests (See full list)
