It all the same. Thats why im triping, its louder to the ear than then just not hair tricking like then.
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
If you could pull a hairtrick with the box at 30Hz than I'm guessing you should be able to at 32Hz.
I don't know what to tell you, other than go back to 30Hz :pardon:
This is why you don't make changes all at once! Check your sub wiring, your amp, etc. I'm not a guru, but if you go from 1 ohm and change impedance to .7, then your amp needs to be readjusted. Not sure, but it might be due to sending a distorted signal without the amp being adjusted with the impedance change. Other than that, unno.
10501650_10203332501847103_1859383749711
Blown
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
