2 15's In A Mustang, A3000db Videos All Tonight
ok 2morrow im gonna try and get the pieces in for a quick test fit
if i get the chance ill take pics just for sumthin to look at
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I agree somewhat with ya bro but I have always found that if you have less power than you want/need, than a sliightly larger box and port will help the efficiency issues. if you look at my box and steves and some others we are running about half of the reccomended port area for our enclosures but putting alot more power to them. Do I think he needs more port? Yes just because of what he is putting in there. The fact that he is running lower power to the subs is a + factor on top of that. Just my .02 cents worth.
Ok -I didn't know you had used brad nails (not a bad idea since they're waay less time consuming than screws) but you're right those would be a b*tch to undo.
That said, just make the best of what you have there. The build looks good and well thought out but as the guys have mentioned make sure it fits at every step along the way, just to avoid an unfortunate situation.
As far as what roscoe said...i dunno what you thought I meant but we said the same thing in our posts:
-with small port, more power would help...
-with lower power he might be in ok shape with those "smallish" ports...
-but more power and or port would help the efficiencey...
-given the smallish ports, lower power levels might lower port velocity and nullify the port noise issues.
I think we're totally on the same page maybe I just said it funny the 1st time?
that said:
http://www.soundstream.com/amplifiers-xstream.htm
300x2 RMS @ 2ohm
150x2 RMS @ 4ohm
Just so you know what you're dealing with.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
as far as i see it the ports should be fine however if they turn out to be too small and make alot of noise ill open em up a little
and i test fit the pieces today and i actually did find a problem. on the back of the seats there is the carpeting with the plastic in it that makes the funky shapes and contours, u know wut i mean? anyway it seems that that will push the entire box back about two inches (and it causes massive vibrations that sound like shit) so im going to get rid of that ASAP. only a minor setback but the box fits perfectly from the tests i did. the only problem i might need a little help with is mounting the baffle with the subs attached. its gonna be really heavy and flimsy, but i should have three people there so we might be fine
gonna try and get work done today and get some more pics up
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
ok this will give u guys a taste of how im mounting my subs
Posted Image
Posted Image
Posted Image
it loox kinda cool. and u might notice that the cut out is a little bit too big (oops :blush: )
well its just big enough that the holes are going to be really hard to use. so i came up with another idea
Posted Image
i put one on just to see how well it holds and i think eight of them would hold me so i think my subs will stay in place
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
how are you gunna be able to get the subs out if something where to happen? take apart the whole box?
2005 Nissan Altima 2.5 S
HU: AVIC-D2
Fronts: ARC Audio KAR KS6006 Components
AA Poly Mids/ CDT CW-19 Tweets in kicks
Front Amp: Profile AP400x2
Rear Fill: None
Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps)
AMP: RF t10001bd x2 (1400-1500 @ 1 ohm)
Wire: Welding Supply/Lighting Audio 1/0 Power/Ground
Zero Noise 2.0zn RCA (x2)
260 Amp Iraggi Alternator
basically yea but this is an everyday system so i wont be pusihing it to its limits (alot)
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
todays work not alot just mounting the brackets and cuttin some stuff out for clearance issues and mounting up the baffle
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
doesnt look like alot of work but it took a couple hours. its all that precision stuff that takes forever. u guys know how it is
a couple more days of cutting and sanding and painting and it should be ready to put in the trunk
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Hell I probably read it funny....my little brain does that sometimes when I get tired........ :wacko::rolleyes::D
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
this is a nice build, very inovative too, with those mounting blocks thats a damn good idea.
thanx man that really means alot to me that im doin sumthin right
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
