Sub stopped working earlier while driving around. Got out to check the wiring, amp was still on. Found THIS.
Thoughts. Comments. I'm guessing my problem is too thin of a wire?
Inside the box and sub are wired with 8ga.
(sorry, Flickr is acting weird and not letting me post pics to ANY site for some odd reason, unless I'm missing something)
1996 Vw Jetta
Crunch 1500watt
1- Kicker 15" L7 @ 1ohm in a 4cu. ft. Ported Enclosure Tuned to 32Hz.
4- 6.5" Menace Door Speakers &
2- Menace super tweeters in the dash
139.11db @ 40hz (6/2010..old amp setup)
It looks like to thin of wire like you said. Maybe them cheap terminals had something to do with it. It reminds me of Schoshe brand fuse blocks. They melt mighty quick. Cheap pot metals to blame. I'm assuming the L7 is okay right?
Derp.
Yeah, the sub is perfectly fine. Looks like I need to get new terminals and thicker wire. How thick should I do?
1996 Vw Jetta
Crunch 1500watt
i went wit 8g, you can go with 12g too if you want to go smaller than a 8g wire.
for terminals, i wouldnt use those "cup terminal" things i would drill some holes and use some plain nuts and bolts :good:
EDIT: cant spell
Wires to small causing to much resistance, causing lots of heat and then leads to melting
take baby steps, u cant do it all at once unless u have a roll of 100's big enough to choke a donkey
1998 Chevy Venture "Swagger Wagon"
Kenwood Excelon KDC-X994 Headunit
3 15" Alpine Type R's in seperate T-Lines
1 RF T1500-1bd for 2 of the 15s
1 RF P1000-1bd for the single 15
3 sets of Hifonics Zeus ZXi6.5C Components( 1 more set to come for Front stage)
1 Hifonics HFi100.4 4-channel amp
Stock alt for now (DC HO SPL 400A when funds come in,currently working on buying this)
Stock battery and one Optima Redtop for now (looking at XS batteries)
3 15" Alpine Type R's (aka Swagger Wagon Build 1.0)
Swagger Wagon Build 2.0
Youtube Videos
  • Who's Online   1 Member, 0 Anonymous, 2330 Guests (See full list)
