lil_mac Posted July 30, 2010 Report Share Posted July 30, 2010 ok guys here is my problem, i have a memphis mojo 4kw and about 2 weeks ago i was driving and nothing worked my voltage dropped and came back up and continued to do so i unhooked everything from the battery thinking my battery was bad so i take it to look looked at and the battery was good with 12.9 volts. so today i decided to take a look and check wiring and found that my ground had come loose so i put it back on tight checked all other wires and it blew my fuse, amp didnt turn on. so i go down and buy another fuse thinking i blew the first one cause i hooked it up wrong or something and as soon as i start my car this one blows WTF i dont get it!!! why would i keep blowing fuses? any help would be greatly appreciated!! thanks in advance Quote Link to comment Share on other sites More sharing options...
ant the ninja Posted July 30, 2010 Report Share Posted July 30, 2010 re-check your ground, make sure its on bare metal. Quote 2002 Ford Explorer XLT Front Stage: Crescendo CCX 6.5's Rear Stage: ??? Two 15" Powerbass M154 Audiopipe AP15001d Pioneer DEH-P5100UB Link to comment Share on other sites More sharing options...
lil_mac Posted July 30, 2010 Author Report Share Posted July 30, 2010 ok i will do that thanks! any other ideas if thats not the problem? Quote Link to comment Share on other sites More sharing options...
alpinebeats93 Posted July 30, 2010 Report Share Posted July 30, 2010 ok i will do that thanks! any other ideas if thats not the problem? what ga. power wire and ground are you usin? Quote Link to comment Share on other sites More sharing options...
lil_mac Posted July 30, 2010 Author Report Share Posted July 30, 2010 zero Quote Link to comment Share on other sites More sharing options...
alpinebeats93 Posted July 30, 2010 Report Share Posted July 30, 2010 zero oh, ok then, well then it aint clippin, juss make sure your ground is on bare metal Quote Link to comment Share on other sites More sharing options...
Alex K Posted July 30, 2010 Report Share Posted July 30, 2010 Yeah it sounds like a grounding issue. Is there any bolts you could ground too instead of sheet metal? I know thats been a problem for me in the past. Look for a bolt thats connected to your chassis Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
mbdblue Posted July 30, 2010 Report Share Posted July 30, 2010 (edited) oh, ok then, well then it aint clippin, juss make sure your ground is on bare metal not really what clippin is... but blowing fuses means its shorting out...make sure your power wire isnt gettin crimped by anything and has a clean run to the back or from a back battery (which I hope you have with a 4kw memphis). Edited July 30, 2010 by mbdblue Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
alpinebeats93 Posted July 31, 2010 Report Share Posted July 31, 2010 not really what clippin is... but blowing fuses means its shorting out...make sure your power wire isnt gettin crimped by anything and has a clean run to the back or from a back battery (which I hope you have with a 4kw memphis). like when i had my kicker hooked up i was usin an 8ga power and ground, so it when i would turn my radio up loud it pulled so much it made the amp shut off and come back on, so i had to go to a 4ga, when it does that its clipping Quote Link to comment Share on other sites More sharing options...
lil_mac Posted July 31, 2010 Author Report Share Posted July 31, 2010 thanks for all the help guys ill make sure i look at all that tomorrow Quote Link to comment Share on other sites More sharing options...
