need to make sure the ground on the rca is properly touching the amps ground part, sometimes you may have to take a pliers and bend the ring around the rca in just a bit so it tighter around the rca on the amp, do the same for the heaunit side, if it doesnt ground that, you will get lots and lots of noise :D
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
http://cgi.ebay.com/ebaymotors/PAC-OEM-Integration-RCA-Ground-Loop-Isolator-SNI-1-/370491737344
THIS IS ALL YOU NEED no joke i had some BAD engine noise and as soon as i hooked it up NOISE WAS GONE...if it dont work after you plug it in make sure you ground the wire that it comes with like to your cd player trust me you wont me dissapointed
Ive ran different RCA's to the amp and still had the problem. Its not the RCA's its defiantly the ground wires I have coming from the front to the back. I unhooked those a put a short wire hooked up to the seat bolt and boom noise gone. As soon as I put the ones from the front back on Noise again. I just don't understand why that is as I hear many people have ran grounds directly from the front battery to the rear with no problem
Team DOA
Team gg
Maybe your RCAs and power wire are too close and causing the noise
'Tis a myth.
I would say yea, for the most part, cause rcas have shielding, and also because they are twisted, so you really dont have to worry about noise, unless you bought some ghetto wtf rca's, ha ha
Pioneer 4300DVD
  • Who's Online   1 Member, 0 Anonymous, 639 Guests (See full list)
