More Watts=More DB's???
g6ryder
ok i have 2 12" kickee L7's i HAD them hooked up to kicker zx1500.1 i hit 140.3 db stock 125 ALT. big 3 extra battery stay about 14v i sold the kicker amp and bought a HIFONICS XX-COLOSSUS which is 3200 rms at 2 ohm bridged 1100x2 rms at 2 ohm subs are in a 4.8 cubic ft its the largest box i could get in my pontiac G6 trunk will this new hifonics amp raise my DB's? is this a good amp?
www.wooferwarehouse.com
its all in box design and how smart you use your power.
2006 Nissan Z Track.
My Feedback Thread
the box is tuned to 40 htz for higher spl the box design is great just wanting higher numbers
That box is a little big for giving those 1100 a piece..
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
oh jeez..... :nothingtoadd:
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
x2 on what Kranny and Alex K said.
For the record I run a Hifonics BXi 2610D amp on my 2 12" L7's with no problems whatsoever. Also, my current box is about 2.3 cubes per woofer at 38Hz. You'll be fine on your power as long as you don't slam the gain all the way up. Properly set everything.
Derp.
The gain will set low for my daily driving but turned up for comps I was guna bridge my subs for comps so they will get 3200 rms for comps only tho??
why is that a question? lol
you should increase in dB but i wouldnt expect too much. box design is a much bigger factor than power
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Well bc I was kinda asking if that was a safe amount of power 3200 rms. Ya well thanks everyone for ur help ill let u know thanks again
  • Who's Online   1 Member, 0 Anonymous, 1810 Guests (See full list)
