deepsilencer's Walled 08 malibu LTZ (V.2)
its an 09 theres a few im on here im not much of a picture guy.
Are those dimensions the absolute biggest we can fit in the trunk, and has to be loaded through rear seats right.
with deepsilencers car we loaded the box through the trunk you just got to pull the plastic trim along the back edge of the trunk around the trunk latch for clearance
my box is bigger than his widgth wise and yes through the backseat. after I pulled the trunk carpet the spare tire and the rear deck under carpet. Then went to town on two pieces of angled metal (one on each side with a big ass hammer) I wouldnt do it again.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
SNEAK PREVIEW/NEW UPDATE
I ADOPTED ANOTHER KID FOR THE MALIBU :drinks:
THIS IS THE AQ3500D.1
IT'S ALREADY STRAPPED TO MY OTHER 3500
I HAVENT REALLY MUCH DONE A LOT OF TESTING CUS I WAS REALLY BUSY FINISHING
THE SILVERADO'S BOX YESTERDAY,BUT IT'S HOLDING ON PRETTY WELL
NEXT TO THE OLD AQ3500,THE OLD ONE IS GOING IN FOR THE 8S IN THE SILVERADO
THAT IS ALL FOR NOW =) ,PICS AND VIDS ON THE PROCESS :good:
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
Got any more pics of how you ran the power wire, im running wire this weekend in the same car 09 Malibu any pics would greatly help and been wondering the dimensions of your box so i can see how big of a enclosure i can fit in there, it will be 2 12" Xcons on a Soundstream Rubicon 2500d. Thanks.
the wire went through the driver side,
towards the driver's door hinge
and inside where the hinge is at there's a black pre made facotry hole already made for you covered on a really thin plastic
you can push that with you finger and if you have fat hands u can push it with a flat head
once your done doing that
you are going to be able to run 0 gauge through that hole,
allows you to run only 3-0gauge runs.
you can remove the door for easier access but i wouldnt recommend it
never ends up mounting the same.
any ways once you got that hole out of the way
you start taking the plastic trim by your door
and the one that is by your hood's pulley
once both are removed it would be much easier to have access to get the 0 gauge wire through the other side when you put in the wire through the hole
and there easy cake
once you got all the runs you need 2 or 3
you can use that purple/gray/pink insulation that is inside where that door's hinge is at to cover the wires
and once that is done it would look like if nothing ever went through there
and if you want to run more you can do the same thing on the passenger side but you would loose 5ft+ running it across the hood to get ALL the wire over to the other side
you can do what n8 did
cut through the firewall
its harder but it can be done
goodluck and if you still dont get me
i can take pics after work which it should be around 4.30pm
and my box dimensions are
13.5ht____32w____30d
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
long term id make the box smaller with 2 of those amps on it
true
damn
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
its about 20 degrees outside. I do need to do some work on it but it will be way later. like spring time.
thats the only pic I have at this time.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
fk all over me lol
damn
badass malibu and n8 badass subs :drink40:
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
HOw do you reply on SMD but not to text messages? :angry:
Teamflexissueslong.jpg1995 Sonoma with camper shellJVC KD-R900(12) Incriminator Audio Lethal Injection 15s
Crescendo BC5500 ( sent to me not 18v capable)(7) XS Power d1600(2) 350amp Mike Singer AltsStripper Pole FTW
Member Build Under ConstructionYoutube Videos
lol i did ha
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
  • Who's Online   0 Members, 0 Anonymous, 1912 Guests (See full list)
