donellk Posted August 5, 2010 Report Posted August 5, 2010 Im putting a relay in my moms van for the system! I had one in my cadi in the back getting power from my back battery but im putting this relay in the dash of the van! Should i just run a power wire from the battery or is there anything i can tag it with in the dash? I doubt I could tag it with the power of the head unit i think thats sketchy or would that be ok? Its going to be turning on 3 amps and powering 2 fans! Team Xtreme Amperage Xtreme Audio Innovations XtremeAudioInnovations.com Facebook.com/xtremeaudio321 basics of a 4th order ~ 1993 Toyota Pickup~ 4 linked c notched bagged Fiberglass door panels (5 speakers per door)
n8ball2013 Posted August 5, 2010 Report Posted August 5, 2010 Im putting a relay in my moms van for the system! I had one in my cadi in the back getting power from my back battery but im putting this relay in the dash of the van! Should i just run a power wire from the battery or is there anything i can tag it with in the dash? I doubt I could tag it with the power of the head unit i think thats sketchy or would that be ok? Its going to be turning on 3 amps and powering 2 fans! you can grab it off the vehicle ignition harness just remember to fuse. I like to go to the battery for mine though. I definitely wouldnt do it off the head units power. it wont matter what you are turning on with it as long as you dont exceed the relays rated amperage. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
huh?do-what? Posted August 5, 2010 Report Posted August 5, 2010 i would use the remote from the radio to trigger a relay, then catch a power wire to actually power the fans and amp remote inputs. God damn its hot today. My balls are stuck to my leg.
