Box Designing
Length 35
Depth 26
Height 18
Just wedge it like you said, and I want it to bang haha. Using 3/4 also, thanks again.
Edit: Those are the max
check an see if that will fit then ill tune it :)
was thinking
2 of these if you can afford the cash :)
http://www.madisound.com/store/product_info.php?cPath=404_85_388&products_id=8922
Live life to the full... Then TURN THAT BITCH UP!
hi, so I have an 01 jeep cherokee..a decent amount of room.
the dimensions I cam up with are
20" tall
42" wide
22" deep
the box is for 4 12" kicker cvr's
I wanna tune it around 35hz
wood is 3/4" thick
this box is about 90% for daily
and I was thinking subs up, port back..slot port
Idc on the box shape, come up with something badass :]
thanks
subs: 4 jl 13w1v2 (12.5" cutout), i want all 4 subs up, and port back. Tuned around 32, but idk what would sound best with these cuz they have a fs of like 21hz
Subs up, aero ports back. (make sure you get enough port area)
Hope my max dimensions will be enough to fit all 4 on the top baffle, if not, let me know
height 25"
width 40"
depth 30"
you have some room to work with as far as the height...just let me know if you got any questions
JL doesnt list box reccomendations but on sonicelectronix it says 2.625 cuft per sub...i was thinking like 7-8cuft total after displacement, up to you like i said cuz i'm only giving them around 1kw so yeah
http://mobile.jlaudio.com/products_subs.php?series_id=17
4 ohm model
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
yes i love torres calculator it doesnt do L port though which is what i currently have. by the way your work lookas amazing so far
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
ahh but you see my friend, L ports are just a way of extending the port for more room, if you keep the inner dimensions the same just take the full length of both sides as the port length
Ok OnelivinLarge Your Box is done :) it will sit against your back seat and is tuned to 33Hz
Cut-sheet:
1 x Bottom: 30 x 18.75
1 x Back: 30 x 14.75
2 x Sides: 17.25(Bottom) x 14.5(Back) x 8.5(Front)
1 x Front: 30 x 8.25 ((Port Cut-out- 10 x 2.5) 10 from each side)
1 x Baffle: 20 x 30 (11 Cut-out for sub Centred)
2 x Port Sides: 2.5 x 14
1 x Port Top: 10 x 14
I do like the way you're posting them all in the thread for people like me, but I have one request if at all possible. Could you state the internal volume, tuning, and port area in the final post as well?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 0 Anonymous, 1328 Guests (See full list)
