Speaker amp cuts out at high volumes NEED HELP
Thoroughly check for the wires being pinched, I had the same problem and that was the reason. I swore none were being pinched, I was wrong.
Edited by DGold
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
^^ this or maby its not working right
are the tweets ran threw the comps cross over, and mids going str8 to amp?
also check wires going into cross over cause they might be wired wrong, i had that problem with my kicker comp set, i was moveing the cross overs and i had the wire comeing from amp going into tweet output and tweets wired to cross over input, it worked but distorted bad, but i soon fixed it lol
but i unno what else could be ur problem, does the amp go to protect, or just speakers cut out?
try to unhook each speaker till it stops, or try it without any speakers for a lil bit, i had to do this befor with one of my amps
I will double check for wires being pinched, good idea.
And the amp doesn't shut off or dim or go into protect or anything when it cuts out, it stays the same.
The tweets AND mids are ran through the crossover.
F/s: 2 custom made boxes, for 1 12" and 2 12" hit me up I'll let em go cheap
what kind of components are you running? some crossovers can't handle the wattage, I had a Infinity component set that would cut out at higher volumes. I removed the crossovers and they sounded like a whole new set.
I'm running these (http://www.onlinecarstereo.com/CarAudio/p_19799_MB_Quart_PVI_216.aspx)
even with the gain way down that amps putting out like 20wrms, theres no way it's being over powered....
Hmmm have you tried unhooking one speaker at a time from the amp to help narrow down the search? will also be able to tell if the amp is just bad that way.
maybe too low of a ohm load.
  • Who's Online   1 Member, 0 Anonymous, 530 Guests (See full list)
