moetpoppin Posted August 8, 2010 Report Share Posted August 8, 2010 I bought a kit of resin and it came with the hardener with it. I am used to the stuff at work which was just a clear liquid hardener so I failed to mix this weird hardener paste like substance. I want to get the right kind of hardener that I am used to or at least doesn't need to be mixed before adding to the resin. What kind of hardener do you suggest and where can I get it online? I have tried several local spots and they do not have very many options so a link would be nice. Any help would be greatly appreciated! Thanks TY TY Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy Party and Bullshit - The Notorious B.I.G. Honest estimate on this truck when it's all done........... 172.3........... Ehh.. U are aware of what 172.3 is, right? yep..... Two Pyle 15"s Build log Link to comment Share on other sites More sharing options...
moetpoppin Posted August 9, 2010 Author Report Share Posted August 9, 2010 no body? TY Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy Party and Bullshit - The Notorious B.I.G. Honest estimate on this truck when it's all done........... 172.3........... Ehh.. U are aware of what 172.3 is, right? yep..... Two Pyle 15"s Build log Link to comment Share on other sites More sharing options...
mbdblue Posted August 9, 2010 Report Share Posted August 9, 2010 what are the products your talking about? we cant tell you to get the "right kind of hardener" if we don't know what product your describing. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
moetpoppin Posted August 9, 2010 Author Report Share Posted August 9, 2010 the resin is a "Bondo" all purpose resin. I used the "Cream" hardener that came with the package. However it says to add 14 drops per oz of resin, but it does not come out in drops, more of a runny tooth paste texture and I have no idea how much to add. When at work, I have used a clear liquid that is easy to drip. Is this the MEKP stuff? It sounds like it Let me know Thanks TY TY Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy Party and Bullshit - The Notorious B.I.G. Honest estimate on this truck when it's all done........... 172.3........... Ehh.. U are aware of what 172.3 is, right? yep..... Two Pyle 15"s Build log Link to comment Share on other sites More sharing options...
mbdblue Posted August 9, 2010 Report Share Posted August 9, 2010 the resin is a "Bondo" all purpose resin. I used the "Cream" hardener that came with the package. However it says to add 14 drops per oz of resin, but it does not come out in drops, more of a runny tooth paste texture and I have no idea how much to add. When at work, I have used a clear liquid that is easy to drip. Is this the MEKP stuff? It sounds like it Let me know Thanks TY if it was clear and used for a polyester resin, then most likely it was MEKP. you can order resin and mekp from uscomposites.com or selectproducts.com or fiberglast.com.....but I cant tell you that the bondo all purpose resin will react the same way to that form of MEKP then to the cream. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
EricR Posted August 9, 2010 Report Share Posted August 9, 2010 Something like this usually works for me i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work? Link to comment Share on other sites More sharing options...
Freshman6969 Posted August 9, 2010 Report Share Posted August 9, 2010 the bondo all purpose resin is what i used, i think your hardener might be bad????? i just poked a hole in it with a pin and it was fine, took me a few tries to get it rite so it dident harden to quickly and turn into chunks or not enough so it never dried, i also used the 3M hardener for my second can i bought just to see, same shit really Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
moetpoppin Posted August 9, 2010 Author Report Share Posted August 9, 2010 Something like this usually works for me yeah thatll do it TY Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy Party and Bullshit - The Notorious B.I.G. Honest estimate on this truck when it's all done........... 172.3........... Ehh.. U are aware of what 172.3 is, right? yep..... Two Pyle 15"s Build log Link to comment Share on other sites More sharing options...
fox_racin4 Posted August 9, 2010 Report Share Posted August 9, 2010 the thick paste is for the body filler someone musta messed up putting it in the wrong container you need the clear liquid where ever you go it should sell it seperatly 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
wL<3bass Posted August 10, 2010 Report Share Posted August 10, 2010 the thick paste is for the body filler someone musta messed up putting it in the wrong container you need the clear liquid where ever you go it should sell it seperatly ^^This, you need MEKP aka methyl-ethyl ketone peroxide Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
