Rockford Fosgate T400.4 FS/FT
Ok so I have a Rockford Fosgate T400.4 Multi Channel for sale or trade, It is very lighty used, was just running some RF P162's..LOOKING for a amp to run my Dc lvl 4xl or Diamond D9's, so looking for a SAZ 2000, 2500, or etc.. Will COMBO below for a amp if needed..
Its just a little dusty glare, its not scratched fyi.. thanks
Number of Channels 4
Rated Power
(RMS Continuous Power) 60 Watts x 4 @ 4-Ohms
100 Watts x 4 @ 2-Ohms
200 Watts x 2 @ 4-Ohms Bridged
2-Ohms x 2 Bridged Stable
Total Power
(Sum of Rated Power) 400 Watts
Dynamic Power
(PVC/PowerCube® Measurement) Front Channels
90 Watts x 2 @ 4-Ohms 0° Res
154 Watts x 2 @ 2-Ohms 0° Res
Rear Channels
Bridgeable Yes
Efficiency (average) 69% @ 4-Ohm
68% @ 2-Ohm
Crossover Controls Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls Front Channels - Punch EQ
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels - Punch EQ
Signal Input Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Also Have a Diamond 600.1 Mono,
• Class D amplifier topology
• Stable into 1 Ohm mono load
• Strap two D600.1 for over 1200watts @ 2 ohms
• 24dB/Octave low pass filter (50-250Hz)
• Pass-Thru line output for daisy chaining amplifiers
• Remote level control included with amplifier
• Pulse Width Modulated MOSFET switching power supply
• Extruded aluminum heatsink
• Nickel plated RCA low level audio inputs
• Nickel plated power and speaker connector blocks
• Power on and protection LED lighting for easy diagnostics
• Thermal, short circuit, and low impedance protection
• 0 - 12dB bass boost
• Chassis mounted ATC/ATO type automotive fuses
• Proudly designed and engineered in the USA
RMS @ 4 Ohm 275 Watts x 1
RMS @ 2 Ohm 450 Watts x 1
RMS @ 1 Ohm 600 Watts x 1
Crossover LP
THD <0.02%
Frequency Response
20 - 20,000 Hz
A Jensen VM9312HD id like to sell or trade along for a Amp..Has HD Module and receiver
Please LMK Thanks!!
Edited by SubSonic
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
I really want to try to get a trade for a Amp for my woofers but if all falls through - $230 plus shipping - Not written in stone just obo more or less around that..
how much you asking for the rf amp
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
Aren't those specs for the new T400-4? I thought it was something like 25x4 at 4 ohms and that they're stable at 1 ohm. I could be wrong though. Could you post the birth sheet?
Edit:spelling
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Edit:spelling
You are correct about those not being the right specs.
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
  • Who's Online   1 Member, 0 Anonymous, 346 Guests (See full list)
