Make a knocking noise, or another bass note?
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
you can tell its not part of the song, the subs will just start making knocking noise but the song will keep going and its like on every song. its hard to explain
almost sounds like an rca issue. check all your wiring and make sure everything is tight and no wires are pinched. try un hooking the rcas from the amp and see if it stops. maybe try a different set of rcas. what kind of head unit do you have
2015 silverado crew cab
nothing atm but soon...
A Knocking noise can be the enclosure walls being loose, or as stated above the woofers not screwed down tight, or it can com from the sub itself and may be the dust cap popping off, or spider coming loose, or tinsel leads slapping the back of the cone. Or at high excursion it could be the voice coil rocking and hitting the pole, or bottoming out and hitting the back plate.
So just saying your sub knocks isnt descriptive enough to tell. Gotta get a closer listen and check some of those things off the list.
Ed Lester
ShowtimeSPL Host
My old Build Log
everything is down tight, i think it might be an RCA issue now that you say that, the head unit is a Alpine iDA-X303 and i have had issues with it before to
  • Who's Online   0 Members, 0 Anonymous, 2587 Guests (See full list)
