Using a fuse for your alt wire??
i already have a ton of 1/0 from my co-worker. i also have 1/0 for the amp and everything.
yea that's fine. you could run the 1/0 from your batt to your alt without a fuse, but if something shorts out or anything. the weakest link is going to fry. be it your wire, or alt, or worse.
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
Really, you don't have to run a fuse. He doesn't run any fuses, because he trusts his wiring and such. Big competitors also don't run them. There is a reason for this. Fuses restict current flow. Another reason is, its cheaper to not have to buy, 15+ 1/0 fuse holders and fuses.
1985 Chevy Silverado Black and Silver SBC 350/700r4
yea, thats what i was thinking as well. Right now i only have my 200 amp fuse that is 3 feet from my batt to the fuse holder. then the 1/0 keeps going straight back to my cap (which i know is shit but it worked like a charm for my old school 500 watt amp) and from the cap right to the amp. so the fuse in my engine is all i have. the only thing i was thinking to do is that my amp is old and doesnt put out enough power i can feed my woofer so i was going to get an audioque 3500d.1 amp which takes 2 inputs of 0 gauge. i was thinking to keep the 250 amp fuse in my engine as well as having a xs power d3100 in my trunk (to replace the cap) and from the d3100, ill use a short run of 1/0 to the amp and have each positive have a 200 amp fuse. do you think that its too much power loss from using 3 fuses? i really dont need a car fire since i almost lost my car from it (stupid 4 gauge wire came loose on a "0/4 gauge compatible" anl fuse holder and caused it to get loose, melt the wire, and burn up without blowing the fuse at all. but let me know what you all think of what i plan to do when im upgrading the amp to the aq 3500d.1
  • Who's Online   0 Members, 0 Anonymous, 807 Guests (See full list)
