well kinda, I've had the stereo in for less than a week. Or at least the sub and the amp.
yeah but 240rms should not do that i would take and have your bat tested and hook up a dmm and test to see if u r getting over 13-14volts if not could be the alt
but my guess is your bad is shit (no offence ) cuz if its a old bat it cant take the extra draw mine did that and i replaced mine no problems untill my 20year ld alt died
1) lookj to left
2) NOTICE BLKUE
3) ME > Y9OU
4) that is all
usually when the dash lights up with a battery, tends to be an alternator charging problem.. at least im fairly certain of it
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
With newer GM's that is exactly what the warning is (service charging system).
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Since you said you lost power steering i would think the belt popped off or broke as usually the alts will share more than 1 thing with the belt. Start there and work you way through everything else.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Captain obvious to the rescue! I didn't even see him mention power steering... :drinks:
Pioneer X8500
Second Skin
2 270a Mechman Alts
Thanks guys! So I got it looked at. Maybe you can help me figure this out bc I'm still confused but apparently the alternator pulley is cracked and the belt is really worn out. Think it even snapped when I took it to the carx. Basically they r given me a new alternator (free since it was already replaced) and two new belts and a power steering flush. I still don't get how it happened though he said that it's bc the power steering pump like locked or something. Does this make sense to you guys?
It's possible, the belt could have been too small too or just a defective pulley.
Pioneer X8500
Second Skin
2 270a Mechman Alts
