Whining in speakers(follows rpm)
Okay guys, so I have that whining noise in my speakers that follows the rpms. I have dual batteries, 4 speakers of the h/u, 2 amps & 6 speakers off those. Ive ran the rca's as far away from the power as I can. Short grounds to the seats. Turned the gain down. Replaced the rca's. Checked my grounds. Checked my remote wire. I have no idea what it could be! Please help, Thanks a lot!
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
which speakers? sub or just speakers? and you grounded to the seat bolt..??
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
pioneer headunits are NOTORIOUS B.I.G for this problem. take a piece of speaker wire and wrap it around the outside of the RCA's (the large circle part, aka the - part on the RCA) and snake it around to make sure it makes good contact with all the RCA's (whether it be 2 or 4 or 6) and then screw it to an existing screw on the headunit chassis. noise should be completely gone.
a+ ^ beat me to it, it's either that or put LOC's in and not use the deck at all either way will work.
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
^^^ x2, thats totally true
I think the grounds to your seat posts might be a problem also, my friend told me its a ground loop that could be happening, and that its better to just recreate a new ground else where
Owwwwwwwwww
Badda Bing Badda boom! Thanks a lot guys that was awesome! :clapping::woot:
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
yeah its probably a ground loop
the speaker wire thing worked?
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
Yea it did! Fastest question with problem solved I have ever had
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
  • Who's Online   0 Members, 0 Anonymous, 3480 Guests (See full list)
