LT.Smoke Posted September 2, 2010 Report Posted September 2, 2010 Oh god, I love marketing BS in the feature list... I'll translate to english... Magnetic induction regulated drive power supply - Has a power supply, with transformers, like 99% of other amps. Pulse Width Modulated high-current matched MOSFET devices - Power supply uses PWM driven MOSFETs, like 99% of other amps. Class DE technology utilizes elevated efficiency platform technology - Probably just class D with something slightly tweaked 90% High density construction surface mount technology - We cheaped out and used loads of tiny surface mount parts instead of more durable through-hole parts Metallized high temperature low ESR capacitors - Has some caps in it, like 99% of other amps. High speed audio grade low level stage components - Has some op-amps in the pre-amp section, like 99% of other amps. Balanced Transformer-less Logic input for highest possible damping factor, slew rate and S/N ratio - It's a Class D amp Stability filter design for reduction in noise - Uses a feedback loop, like 99% of other amps. Wired remote bass level control included - Has a bass knob LED power (green) and protect (red) indicators - Has LEDs Variable Bass Boost (0 to +20 dB bass boost at 45 Hz) - Has bass boost Time delay soft start turn on - Muting relays to prevent turn-on pop, like 99% of other Class D amps. Mono channel operation - It's a monoblock Preamp RCA outputs to daisy chain multiple amps - Like 99% of other amps. 3-Way System Protection circuitry (thermal, overload, and speaker short protection) - Has slight idiot-proofing, like 99% of other amps. Heavy duty aluminum alloy convection cooled heatsink for extreme heat dissipation - Has a heatsink, like 99% of other amps. Platinum-plated RCA level inputs - Shiny RCAs, like 99% of other amps. Platinum-plated screw terminals - Shiny power terminals Boon you must have missed the newsletter that states that All shiny amps do above rated power LMFAO Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
Chode69 Posted September 2, 2010 Report Posted September 2, 2010 Oh god, I love marketing BS in the feature list... I'll translate to english... Magnetic induction regulated drive power supply - Has a power supply, with transformers, like 99% of other amps. Pulse Width Modulated high-current matched MOSFET devices - Power supply uses PWM driven MOSFETs, like 99% of other amps. Class DE technology utilizes elevated efficiency platform technology - Probably just class D with something slightly tweaked 90% High density construction surface mount technology - We cheaped out and used loads of tiny surface mount parts instead of more durable through-hole parts Metallized high temperature low ESR capacitors - Has some caps in it, like 99% of other amps. High speed audio grade low level stage components - Has some op-amps in the pre-amp section, like 99% of other amps. Balanced Transformer-less Logic input for highest possible damping factor, slew rate and S/N ratio - It's a Class D amp Stability filter design for reduction in noise - Uses a feedback loop, like 99% of other amps. Wired remote bass level control included - Has a bass knob LED power (green) and protect (red) indicators - Has LEDs Variable Bass Boost (0 to +20 dB bass boost at 45 Hz) - Has bass boost Time delay soft start turn on - Muting relays to prevent turn-on pop, like 99% of other Class D amps. Mono channel operation - It's a monoblock Preamp RCA outputs to daisy chain multiple amps - Like 99% of other amps. 3-Way System Protection circuitry (thermal, overload, and speaker short protection) - Has slight idiot-proofing, like 99% of other amps. Heavy duty aluminum alloy convection cooled heatsink for extreme heat dissipation - Has a heatsink, like 99% of other amps. Platinum-plated RCA level inputs - Shiny RCAs, like 99% of other amps. Platinum-plated screw terminals - Shiny power terminals THE FUCKING TRUTH....if you want a strong 3k+ amp save up a little more and get a AQ3500.1D VERY strong and reliable amp..i have 2 and i love them...favorite amp to date NoFearX18 said: Nick will bang just about anything.....LMAO....pun intended On 4/13/2010 at 9:51 AM, meade916 said: i was like DAMN, Chode is hardcore! he makes james look like a friendly person LOL! trainman0978 said: I dont know who is worse with the buttholes Chode or Big P... Team Deadly Hertz / Team DC Audio / Team XS Power 2010 DC AUDIO MEMBER OF THE YEAR!!! DuckretaryFEAR THE DUCK Durangho Chodes Blowthrough Build Youtube vids Muh Wife Need DC Audio? Hit me up for pricing!!!
STEvil Posted September 3, 2010 Report Posted September 3, 2010 Standard caps in most amps are aluminium electrolytic already Pretty sure it's just marketing poo-poo. The PC-style solid caps cost way, way too much. Aluminum Electrolytic? what? Solid caps do not contain electrolytic compounds. They do cost more for sure, but they dont explode due to aging (electrolytic capacitors age and become less efficient over time) and are superior to a normal electrolytic capacitor in pretty much any form as long as you're using them correctly. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Boon Posted September 3, 2010 Report Posted September 3, 2010 Aluminum Electrolytic? what? Solid caps do not contain electrolytic compounds. They do cost more for sure, but they dont explode due to aging (electrolytic capacitors age and become less efficient over time) and are superior to a normal electrolytic capacitor in pretty much any form as long as you're using them correctly. Oh right, solid caps like the ones Asus and Gigabyte throw all over the place on their motherboards. Great caps but currently cost a$$loads. And I can't even find them in a useful size at rail voltages. I imagine they would be like $100 each. 10.x volts fo' life!
STEvil Posted September 3, 2010 Report Posted September 3, 2010 make some out of pop cans, its not hard edit - though there's some trial and error.. lol! MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
