CompuStar horn disabling HELP ME!!!
Ok, so my dad has a compustar rf-1wg2-am remote starter in his 1997 chevy tahoe. personally i hate the remote starter on his tahoe as well as another compustar remote starter on my moms car which i hate since they cannot be programmed like my omega remote start/alarm can be. but thats besides the point. im having a ton of problems with my dads remote start in particular. he has the horn output wired up and it does NOT silence at all. i tried to hold the lock and unlock buttons for 5 seconds like the manual says and it will flash the lights and when you unlock, lock, or pop the hatch with the remote the damn horn goes off. ive tried to do this 3 times and nothing makes a difference no matter how long i wait. is there anything you can direct me toward in possibly finding the lead that the horn is tapped into to shut the horn off? my dad hates the horn feature and since he locks/unlocks the truck a ton and he did that so much that he burned out the stock horn on his tahoe and has an aftermarket horn that has a fucked up note and it sounds like a toyota. lmao.
But any help with this would be greatly appreciated. i cant figure it out and thats pathetic. lol.
You don't hold for 5 seconds you hold for 1/2 second. or .5 seconds.
2009 Db Drag National Champ, Super Street No Wall
Team XS-SPL
Team Hertz/Audison
Team Crossfire Car Audio
California's reason for earthquakes!
"If you ain't first, your last!"
wow, that worked. thanks so much!!!!! i read the stupid manual and it said 5 seconds.
alright, so since you helped me with that stupidly easy question maybe you can help address these...
1.) How do you get into the programmer feature so that i can decrease the amount of time the engine cranks to do a remote start?
Right now the engine will crank for about 2.5 to 3 seconds before it either turns the engine over, or if the engine is extremely cold (about 20 degrees Fahrenheit) it will not succeed and will retry the engine starting sequence. Since the engine is usually warm (around 40 to 90 degrees) it starts in like 1.5 to at the most 2 seconds. since it goes this fast and the remote start doesnt catch up on it i wanted to stop the starter grinding that occurs.
2.) When i shut off the car and get out of it and lock up the doors the interior lights stay on for a good 2 minutes. how can i decrease the time or make it so that when i hit the lock button that the interior lights turn off?
Again, i looked at the installer menus and im confused as hell at how to program this unit. any and all help would be greatly appreciated.
Thanks again!!!
you can hook up the tach wire instead of a timed crank
and the doome light staying on is a factory thing.
nothing to do with the alarm.
ok, so how do you wire a tach wire? i have no clue how to do that. ill admit it, im a noob at remote start/security systems but the guys we bought the remote start from screwed up both the vehicles we had them install. if you guide me through it i can do it i can do it.
Tach wire is yellow/black on the unit you'll want to run it under the hood though a safe location, through the firewall and hook it to the white wire on the distributor. Tach programs differently depending on how old the unit is. The dome light is definitely a factory thing, compustar will only hold lights on 45 seconds if hooked up. If i was you I would take it to an authorized compustar dealer and pay to have everything setup the right way you want.
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
even if u hook up tach u still have to take it to a dealer to turn off the voltage scence or timed crank whatever the lazy installer did and put it back on tach scencing
Greg,
Triple C Auto Niagara Falls NY
Under construction
2002 Chevy Suburban
pioneer 8000NEX
3 Sets of ARC Audio 6000 components in custom front doors
2 Powerbass midrange in center council
4 Super tweets
2 Focal 900.6 6 channels
4 American Bass VFL Comp 15's (currently running 2)
DC 12.0k
DC Power dual alt bracket
2 XS Power D3400's under the hood
3 C&D technologies 110ah in rear
along with multiple runs of 0 AWG OFC
  • Who's Online   1 Member, 0 Anonymous, 1692 Guests (See full list)
