Sounds like a plan
Go 1-3 steps colder with a supercharger... being that yours isn't intercooled like alot of other system for that particular motor it probably isn't running much boost so 1 step colder should be fine.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Get the upgraded fuel filter for sure.
If you get the "stock" fuel filter it may not be able to keep up with the fuel flow required causing your burn in the cylinder to become lean (too much air, not enough fuel). With a gas motor this will melt shit!
Pull out a plug and look at the end. If its light brown in color you're doing ok. Read the data on the plug and get ones that are identical to it.
Hammerdown... 1%
